Home > Maintenance & Mods (L322) > Rear Landcover badge removal |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
Fishing line or dental floss.... Pete
11th Sep 2015 9:21pm |
Warm it up with a hairdryer first |
11th Sep 2015 9:26pm |
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 129 |
That sounds like just the ticket, thanks guys. |
11th Sep 2015 9:39pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
To get the sticky off get a toffee wheel off eBay. Fits in your drill, made of rubber, will gently on a slow speed erase the glue. Gently does it though so you don't damage the paint. There is nothing that can't be fixed with a hammer😜😜
11th Sep 2015 10:15pm |
Thanks Northernmonkeyjones,
11th Sep 2015 11:14pm |
Bit of petrol on a rag is cheaper.... Pete
12th Sep 2015 6:21am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
The rubber wheels are fantastic at removing the glue! |
12th Sep 2015 9:48am |
I know mate, they are very good, but if he's only removing one then a bit of petrol is cheaper and I've found the Land Rover glue to be pretty easy to get off.... Pete
12th Sep 2015 4:59pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
I used boiling water when i replaced the oval Land Rover / Supercharged badge on the tailgate.
13th Sep 2015 6:03pm |
All great suggestions... Thanks for the replies.
13th Sep 2015 8:29pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Pete you forgot to say DON'T use a match Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
16th Sep 2015 7:38pm |
So the job is done. In the end I went with boiling water to soften the glue. I then used dental floss to slide under the badge and it came off reasonably easily. Then used petrol to clean off the residue, which it did easily and with no damage.
25th Sep 2015 8:53pm |
