Home > Technical (L322) > Dashboard warning: <FUEL INJECTION SYSTEM>
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Hi I have a 2005 L322 Vogue 3ltr Diesel, owned by me since new. 140,000 miles on the clock and mechanically been brilliant, serviced every 10,000 miles with Castrol Edge oil and filter. In past week the info screen at bottom of dashboard has flashed up <FUEL> then after 10 minutes disappeared?? The car runs perfectly any ideas or is this an electrical fault, that I can reset by disconnecting the battery to clear the fault codes?
Thanks in advance. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #347076 10th Sep 2015 5:20pm
mzplcg
In all honesty you're only likely to get to the bottom of it quickly by having the fault codes read. The fuel system is quite good at logging faults and it could be something as simple as slightly low pressure, water in the fuel etc. Either way I'd have the codes read incase it is a sign of a failing pump or something which might leave you stranded.
Post #347085 10th Sep 2015 6:28pm
Diver Bryn
Many thanks engine running smoothly and RAC member ship in place :D so will look at codes. Many thanks Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #347104 10th Sep 2015 8:25pm
