![]() | Home > Technical (L322) > webasto heater |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
So i assume yours is broken and you're replacing it with a second hand unit?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Through the wheel arch..... I reckon.
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
as above
Good point you shouldn't have to clamp the fuel, I do recal that they are a pain to bleed, I took the feeds of mine to check the impeller was still working, and it took ages to get the air out. There is nothing that can't be fixed with a hammer😜😜
