Home > General (L405) > More Help Please? |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Went on the m/way for the first time since getting her back only to find she vibrates quite significantly at 65mph +, god knows how the dealer can say it drives perfectly, it just doesn't. It didn't vibrate before the diff was changed though so they clearly fu**ed something up.
6th Sep 2015 7:11am |
dfulgo Member Since: 16 May 2015 Location: Milan Posts: 70 |
...hope I'm wrong but, for what I've read so far, it looks like your car suffered a severe accident which bent the frame etc., did you buy it as new? Maybe it fell down from the truck before the delivery... |
6th Sep 2015 7:21am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 |
Someone from LR & not the dealer ? I'll say it again - if you're not happy, go to a different dealer - if it has a LR warranty, then the work can be done at any main dealer, not just the supplying or local one - if you're not happy, then just walk.... |
6th Sep 2015 7:27am |
Dealer work shop controller has always declared the drive is fine so I rejected his comments, they said a test drive with someone who reports directly to LR is next, I cant drive on m/ways now so will place a call to the local dealer that did that to it tomorrow morning.
6th Sep 2015 7:36am |
I'd talk to Ryan @ LR and check the independence of whoever the dealer is recommending - it sounds like it needs escalating to an independent expert at this point. |
6th Sep 2015 7:41am |
Does it have an OE / OF registration number ? Those were the ones for factory cars - like this |
6th Sep 2015 8:03am |
Original reg PF, hope it wasn't one of those |
6th Sep 2015 8:18am |
...any chance you can get in touch with the previous owner? |
6th Sep 2015 9:11am |
Previous owner was one of the Warburton family (the bread) so assume a very wealthy man, he had it from new. I can usually spot a piece of exterior trim out of place, a seal badly replaced, none factory glass, or painted panels and it looks good on all fronts, cant be sure about the underneath ofcourse so will have to keep pushing for repairs.
6th Sep 2015 9:29am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 |
I know that I am an old cynic, but does anyone know what happened to the hundreds of cars that spent a month on their sides in the Solent recently??? |
6th Sep 2015 10:08am |
Just got back from a short drive, she sits much higher than last couple of days and vibration has gone, still very soft suspension damping so I assume the low ride affected the comfort? |
6th Sep 2015 12:55pm |
