Home > Off Topic > Assistance required in the mechanical aisle |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Morning learned friends.
6th Sep 2015 8:35am |
If it's now turning over because it has cooled down then yes it has seized, bin it and buy a new one
6th Sep 2015 9:28am |
6th Sep 2015 9:39am |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 |
Before you bin it, try running it again with the correct oil ratio, or slightly richer. You have nothing to lose, it may well continue to operate albeit with a little more bottom end knock! |
I assume you have a spark? |
6th Sep 2015 9:40am |
I assume so too Goose.
6th Sep 2015 9:50am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Could a jet be blocked? You do smell petrol after trying to start it I take it? Check the plug is wet after you have been pulling the starter... Previously..
6th Sep 2015 9:54am |
Thx Contra - yep all good there - I took the carb off and cleaned it all out - plug was damp after trying (not soaked)..
6th Sep 2015 9:59am |
If you have compression and fuel, then it has to be the ignition. Have you taken the spark plug out, connected it to the HT lead, placed the electrode end to an earth, the cylinder head for example and pulled the cord to see if it sparks across the electrode? It's easier to see the spark in a dark space rather than daylight. |
6th Sep 2015 10:36am |
I did try that but couldn't see much - I swapped the plug out for another (that I know does already start my Strimmer) but no joy. If I get no speak could it be something other than the plug..? If so - is that a likely issue due to it getting too hot yesterday.?
6th Sep 2015 10:44am |
Not sure about the heat issue, but you will have a small Dynamo that produces the spark. First port of call though is the kill switch. See if this has stuck in the off position thus breaking the circuit. If you can prize it out, remove the wires and connect them to make it permanently live and see if this produces a spark.
6th Sep 2015 10:52am |
Will try that next... So far...
6th Sep 2015 11:11am |
Indeed it sounds like the case! |
6th Sep 2015 11:58am |
Thanks folks
6th Sep 2015 12:37pm |
