Home > In Car Electronics (L322) > Blackvue 650 dual channel installation
FullFatDunc
I'm about to fit a blackvue dual channel.
I'm after a permanent live to connect to.
In the D4 I used a piggy back fuse and fuse 41
Has any one fitted one in th FF and what fuse did you use and how did you route the cables, which is the easiest route?
I'm thinking it's the clock fuse, fuse 40, can anyone confirm?
I found a thread that showed some of the info, but I can't find it again Embarassed AKA DiscoDunc
Duncan
If I'd known I was going to be so thirsty this morning I'd have drunk more beer last night.
D4 HSE MY12
FFRR 3.6 Vogue TDV8 SOLD
D4 HSE MY10 SOLD
D4 SE TECH MY15 SOLD
D4 XS MY12 SOLD
D3 HSE MY06 - Re-Cycled Worldwide
Post #344576 26th Aug 2015 5:57pm
look at welshdragons dashcam install in our wiki.. Thumbs Up ... - .- -.
Post #344577 26th Aug 2015 6:04pm
FullFatDunc
Thanks
Thumbs Up AKA DiscoDunc
Duncan
D4 HSE MY12
D4 HSE MY10 SOLD
D4 XS MY12 SOLD
Post #344579 26th Aug 2015 6:15pm
FullFatDunc
sorry, another Q
im sorted fitting the front camera, but when looking at the rear window for the second channel - im struggling to see the best way to fit it..
any ideas? has anyone managed to get the cables through the grommets into the roof lining and down the D-Pillar ?, or do you go across the roof ?
I really wanted the camera on the window, rather than the roof lining Confused AKA DiscoDunc
Duncan
D4 HSE MY12
D4 HSE MY10 SOLD
D4 XS MY12 SOLD
Post #346129 4th Sep 2015 4:34pm
proser
I ran the wires across the roof lining on the passenger side when I installed the rear one in mine. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #346131 4th Sep 2015 4:38pm
my rear dashcam has the cable going down behind the interior 'c'? trim and down into the offside electronics cubby hole..i've left enough cable so that you can open the tailgate without stretching the cable.. ... ... - .- -.
Post #346136 4th Sep 2015 5:00pm
FullFatDunc
thanks Thumbs Up
do you have a photo of how you get the cable from the roof lining to the tailgate ? AKA DiscoDunc
Duncan
D4 HSE MY12
D4 HSE MY10 SOLD
D4 XS MY12 SOLD
Post #346144 4th Sep 2015 6:29pm
indeed,
Post #346152 4th Sep 2015 7:17pm
FullFatDunc
thanks Thumbs Up
I was hoping to setup up something a little tidier though Confused
ill take a closer look over the weekend AKA DiscoDunc
Duncan
D4 HSE MY12
D4 HSE MY10 SOLD
D4 XS MY12 SOLD
Post #346196 5th Sep 2015 8:05am
if your second camera is waterproof , have you considered mounting it next to the outside reverse camera and routing the cable via the roof trim and then down into the off side cubby.. ... - .- -.
Post #346200 5th Sep 2015 8:55am
JackRegan
I have the Blackvue 650 Dual camera and situated the rear camera centrally - see pic
I will update the post showing the wiring with the tailgate open a little later, as the ones I took didn't come out very well Embarassed
Jack 2024 P550e Autobiography
2016MY TDV6 Autobiography - Gone
2011MY 5.0 SC Autobiography Black - Gone
2005 TD6 Vogue - Gone
Post #346203 5th Sep 2015 9:37am
FullFatDunc
that's the one Jack Thumbs Up
I need to get the cable from the tailgate through to the roof lining ? AKA DiscoDunc
Duncan
D4 HSE MY12
D4 HSE MY10 SOLD
D4 XS MY12 SOLD
Post #346205 5th Sep 2015 10:22am
JackRegan
Don't remember mine going through the roof lining. I think it runs inside/behind the tailgate seal into the car by the passenger side rear speaker through left hand side of the back seat where it joins other wires under the tread plates. Then along through to the passenger side A pillar where is rises to the top of the screen where there is a void it sits behind for it to travel to the rear view mirror? I positioned my front facing camera on the passenger side of the rear view mirror. In hindsight I should have placed it drivers side as it would be easier to plug/unplug.
Don't forget BlackVue recommend formatting the card every week or so rather that letting it constantly overwrite. Apparently this helps with dropped frames.
Not a great description I know, but the long and short of it is I don't recall having to mess around with the roof lining.
Post #346207 5th Sep 2015 10:50am
Blade74
Australia
Mine goes through the roof lining.
I went from the front left pillar(right hand drive) to the back and goes through the rubber cable gland and comes out just near the rear tailgate brake light.
It's very neat.
I used a plastic tongue to get through the roof line every easily.
It's flexible and stiff enough to get through. Took me 5 mins.
It took longer to get up from behind the glove box to the top of the pillar.
I had to remove the pillar cover.
Also I had to remove the rubber seal on the back door opening to get the tongue through the roof and out the back.
Post #347484 12th Sep 2015 11:17pm
FullFatDunc
thanks all Bow down
ill take a loot this weekend (if it stops raining Rolling Eyes ) AKA DiscoDunc
Duncan
D4 HSE MY12
D4 HSE MY10 SOLD
D4 XS MY12 SOLD
Post #347971 16th Sep 2015 8:38am
