Home > Maintenance & Mods (L322) > What size alloys fit on an 07 Supercharged?
dubbs
United Kingdom 2007 Range Rover Vogue SE Supercharged Buckingham Blue
Had a good look using search and couldn't see anything definitive.
I'm about to get 4 new wintracs fitted on the standard 9 spoke S/C 20" alloys but before I do in an ideal world I'd have something winter/AT based on a smaller alloy then keep 20" with summer tyres.
Seeing some of the deals for alloys with tyres on ebay it makes you think this'd be a good way to go.
What will fit though? I've heard RRS alloys will fit on FFRRs but then that you need 19"+ alloys to get over the Brembo brakes.
A nice definitive answer to the following would be great:
1. What is the smallest alloy that will fit on a 2007 supercharged FFRR
2. What tyre would need to be fitted to keep the speedo accurate,etc.,
3. Do RRS alloys fit the FFRR
If anyone can/will answer I'd be very grateful Smile
cheers chaps.
Post #34535 1st Nov 2010 11:18am
dubbs
No one?
Post #34605 1st Nov 2010 11:01pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
19" is smallest with Brembos Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #34606 1st Nov 2010 11:18pm
Fox
1. As said above, 19 inch rims are the smallest that fit over the brakes.
2. 255/55R19.
3. Yes, they fit. BUT they have a slightly different offset so stick out a bit more. I'd stick with FFRR rims personally, there are sets of 19 inch rims that are for FFRR coming up on ebay fairly often.
Post #34611 2nd Nov 2010 8:02am
dubbs
Thanks guys, much appreciated Smile
Post #34617 2nd Nov 2010 9:25am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I think you might have a problem with tyre pressure warnings unless you get the sensors moved over
Post #34687 3rd Nov 2010 10:02am
not every RR has tpms and if it dies have it then the sensor will still be in range of the receiver... ... - .- -.
Post #34688 3rd Nov 2010 10:09am
