Home > Maintenance & Mods (L322) > Did LR make a boot divider for the L322?
rumble
Seeing as my 'Wanted' post http://www.fullfatrr.com/forum/topic33613.html seems to be getting no response... I thought I'd check.
I have a LR divider in my Discovery, it bolts onto the full height dog guard. I am having trouble finding this for the L322 but would like to avoid non-OEM versions as I already have the full height dog guard for the RR.
Any advice welcome
Post #345492 1st Sep 2015 1:50pm
duckworthparts
Site Sponsor
LR didn't produce a divider i'm afraid. You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #345494 1st Sep 2015 2:02pm
rumble
Thanks Dan, that would explain why I'm having so little success. I shall have to go for something aftermarket or buy a dog cage of some sort.
Post #345497 1st Sep 2015 2:27pm
CEEGEE
I have had boot dividers from travall.co.uk who seem to be the largest after-market supplier - they seem to do them for every Land Rover vehicle (inc the 405), but nothing for the 322 Confused
It looks as though Barjo, do a guard and divider - http://store.barjo.co.uk/car-cages-land-ro...-dog-guard
In terms of cages, I had one from Barjo for my old RR Sport, which was excellent, but expensive - I also hear good things about the transk9 cages Thumbs Up
Post #345501 1st Sep 2015 3:04pm
proser
For cages I have got one from pet planet. It has one sloping side that it about the same angle as the back of the seats. It's the right size for our labrador and only take up half of the boot space.
We also have a bog standard one that uses the whole of the boot - this is used when we take our lab and her sister for walks at Cannock Chase. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #345503 1st Sep 2015 3:27pm
rumble
Thanks for the replies.
It looks like a dog cage is the only option. Always heard good things about Trans K9 so I'm going to see which is their boxes is the most suitable.
Post #345506 1st Sep 2015 3:40pm
Zirconblue
shouldn't take too much effort for a metal fabricator to make one.
It'll bolt to the full height load guard at the front and, and you should be able to fit a bar across the floor at the back between the two lashing points to attach it to at the back end.
The only issue i can see is the spare wheel cover, you'll still want to be able to lift that up, which means the divider needs an easy way of removal.
Post #345510 1st Sep 2015 4:07pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Lintran do very good boxes. I have one in my L322. They do 1/2 boxes as well see http://www.lintran.co.uk/custom-range
Post #345517 1st Sep 2015 4:25pm
Herdwick
Had the same problem, resorted to making one from a piece of plywood and a couple of brackets to fasten to the metal dog guard.
2 bolts to undo by hand to remove to get to the spare wheel. Maybe not the smartest of setups, but its difficult to see it through the privacy glass, and very effective.
Post #345638 2nd Sep 2015 11:14am
