Home > Technical (L322) > 'Hunting/juddering' on L322 02 Diesel |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 |
Hi Everybody!
31st Aug 2015 6:39am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
My guess would be partially blocked fuel filter - perhaps with trying to drag the dregs of the fuel tank through it when low the other day. (Prepares to cower behind chair from barrage sent by those that actually have an oil burner)
31st Aug 2015 8:52am |
Thank you, Smutt. No one else had any different ideas.... however ( and I am sorry for the VERY late reply but... ) within a couple of days the juddering/hunting had ceased! Happy Days.... in fact it has driven like a beaut , until a week ago when , after the fuel had gone to just below 1/4 tank, it started all again .
28th Sep 2015 8:43am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
having this problem with a 1/4 tank of fuel is an indication of one of the fuel pumps being faulty..[i think] ... - .- -.
28th Sep 2015 9:11am |
Possibly drawn dirt from the tank and now the fuel filter is now choked, worth changing before the pump as it's the least expensive option |
28th Sep 2015 9:40am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
How many miles has it done? Only if your around the 100K mark it could be the injectors , which is not uncommon with a TD6 . Do the filter and if it's still there then I'd look at the injectors, if it does it all the time regardless of how much fuel is in your tank. Yesterday I couldn't spell Engineer... Today I are one!
28th Sep 2015 10:45pm |
Talk to these people, they are up your way, they sorted my injectors and rebuilt the nackered ones for a lot less that you can buy them online, and they'll do diagnostics on the engine if you don't want to get your hands dirty
28th Sep 2015 10:50pm |
This was my fun and games earlier in the year http://www.fullfatrr.com/forum/topic33098.html Yesterday I couldn't spell Engineer... Today I are one!
28th Sep 2015 10:53pm |
Thank you for all that. I will see what its like after the service and then take your advice etc.
29th Sep 2015 6:08am |
Now that I'm in the know after the catastrophic failure of my injectors, I think that I can honestly say that it was playing up for months, but as it was in the background, and intermittent, I just put it down to being a ffrr and possibly a bit of water in the fuel.
29th Sep 2015 9:57am |
Hi everybody !
2nd Oct 2015 6:24am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
If it were mine, i would have the 6 injectors out and into a Bosch specialist for checking/cleaning etc... If no fault is found? At least you will have clean injectors/better fuel economy & piece of mind...
2nd Oct 2015 8:19am |
Talk to Fastline they quoted me £65 per hour, and were confident that they could find the fault in an hour, plus they are a Bosch agent and they will rebuild for £135 + vat and give a full Bosch warranty They will clean and test for £17.50 per injector and wave this fee if it's rebuilt, can't say fairer than that
2nd Oct 2015 12:05pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
You can read the values for the fuelling of the cylinders using the IID Diagnostics tool. I've had a similar problem, re: link below
2nd Oct 2015 1:12pm |
