Home > In Car Electronics (L322) > Reversing camera fuse
J90
France 2006 Range Rover Vogue Td6 Java Black
Hi guys. I tried the search function without success but is there a fuse for the reversing camera? I've lost the image on my screen today. Everything else works, i.e. the reversing beeps but I have no image. I just wondered if it was a fuse thing rather than the actual camera or connections.
Ta.
Post #345125 30th Aug 2015 1:05pm
Battery reset sir Thumbs Up
Post #345129 30th Aug 2015 2:53pm
J90
Thanks Craig.
Post #345189 30th Aug 2015 10:12pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi
My fuse (on the camera ) Laughing went last year it's a 5amp fuse on rear fuseboard i think postion 12 - I just looked at all 5amp fuses 'till i foudn it!!
Cheers
RP
Post #345232 31st Aug 2015 8:35am
J90
Thanks RP Thumbs Up
Post #345268 31st Aug 2015 10:52am
dvb247
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Bonatti Grey
I have no image on my rear cam as well, where is the rear fuse board so I can check the 5 amp fuses?
many thanks!
Post #358122 22nd Nov 2015 6:25pm
Weegie
Right hand side of boot behind the removable panel. John
GAP iiD BT
Post #358131 22nd Nov 2015 6:57pm
dvb247
Thanks, I'll have a look tomorrow Thumbs Up
Post #358141 22nd Nov 2015 7:20pm
dvb247
No 5 amp fuses have gone, it may have been swapped for a higher amp fuse though, I will try and post my rear fuse box, hopefully someone here can guide me, cheers!
PS whats the loose wire for?
Post #358348 23rd Nov 2015 7:39pm
dvb247
What's that Craig in layman's terms?
Will be checking tomorrow if its a 5amp in number 8, which is the number fuse for the reverse camera Thumbs Up
Post #358533 24th Nov 2015 6:39pm
dvb247
Thats not good, my fuses seem to be different ratings from what the manual says they should be on at least 50% of them, so fuse number 8 sopped to be a 5 amp, it's not, it's 30amp same as number 9???
Post #358535 24th Nov 2015 6:53pm
TugRR
^ Funny that - my last FF (also 06 MY) had virtually no fuses correlating to the manual (!)
I decided to close it up & pretend I hadn't looked . . .
Thumbs Up Where do you go after one of these . . . ?
Post #358555 24th Nov 2015 9:19pm
dvb247
So it looks like I need to check the tailgate to see if the wires have broken or unplugged?
Still have a black screen when reversing!!
Post #359385 28th Nov 2015 5:48pm
