![]() | Home > Technical (L322) > Steering wheel judder |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1364 ![]() ![]() |
IIRC you've put new wheels and tyres on it
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
they were great for 1000 miles but will take them off and put them on the ballancer and swap front to rears see if thats sorts it first, might even put the old ones on just strange it needs to get hot |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
double check your tyre pressures. I had the same thing this week, it was a front tyre with low pressure from a leaking valve. |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 ![]() ![]() |
Brake caliper or wheel weight?
^ +1 for possible seized rear caliper. |
Right did 8 miles today wit no brakes used speeding up and slowing down letting the car do its own thing and no steering wheel judder at all.
Well had time yesterday to look for the problem and found the osf disc has a blue high spot on the inside and one bush has a little play in it.
Well fitted new discs and pads in the front done the bush at the same time |
