![]() | Home > Maintenance & Mods (L322) > Westfalia Towbar Removal and cleaning vinyl door cards |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
i think i may have confused things by putting up a pic of the wrong item but referring to it as 'similier'.. ... - .- -.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
No need to bother removing the electrics.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It comes off attached to the plastic bumper cover, so you would have removed it, but put it back on again with the bumper cover afterwards. |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Checked the boot for the Tow arm but it wasn't in the box. There was a black bung however so that's in place now and makes the whole thing look a lot better. Bit of paint on the Armature and the back box and will be nearly as good as new.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Did you use the lifting device (for want of a better description) to remove the spare wheel? John
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
isnt there a strap that you tie to the wheel to aid pulling it out? cant really remember. |
That's what I was referring to. Not tied to the spare wheel. Sits under it with a hook arrangement which is attached to the lower tailgate when in the closed position. Opening the tailgate lifts the spare up and onto it. Then slide off. |
up to around 2005 there was,
Does that mean the stopped it, Stan? John
looking in the later handbook on topix it looks like they did. Don't see why it couldn't be retrofitted though. |
i remember reading here that when ford took over [circa 2005] they done away with this feature... ... - .- -.
except Ford took over Land Rover in 2000, although the L322 was largely developed under BMW, they'd actually sold off the Rover group 2 years before it's launch.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
Ah I remember now that is indeed the case, I have two bits that I removed permanently but would have noticed that hefty thing lying around. You do need two people for about 10 minutes to do the heavy lifting. Geoff |
Magic sponges arrived this morning so gave the seats a good going over with them and some leather cleaner rather than water and can vouch for the fact that they removed the years or grime and dirt giving a near new finish! Will still need a stain as there are some scuffs but overall a great cheap tip to clean the seats from axle! |
