Home > Technical (L322) > Engine management fault
Bungal
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi
I have had the above error come up twice this week on the dash display but had no error lights and the power drops loads as well.
I have a 2008 TDV8 3.6.
No warning lights just the message on the dash display and it disappears when the engine is switched off and restarted.
Anyone with any ideas?
Brian L
Post #344048 24th Aug 2015 4:27am
ebajema
I think the first thing is getting error codes read and see if there is anything that you can do with that. MY 2010 5.0 SC Galway green and sand interior!!
Post #344074 24th Aug 2015 8:21am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
The famous split hose maybe?
Post #344078 24th Aug 2015 8:32am
Bungal
I will plug in my IID when the wife gets home and grab some codes.
Other than that the beast is running like a dream. 30+ mpg and flying.
These cars love to catch you when your not looking lol.
Are the silicone turbo hoses any good?
Post #344177 24th Aug 2015 5:03pm
Top turbo hose, is a good place to start. See the wiki for how to repair/replace. It's super easy.
Silicone hoses are generally better than the rubber ones but the rubber ones are pretty cheap and do last a good number of years, so replacing the top ones as a matter of course every 4 years or so should prevent another failure.
Edit:
http://www.fullfatrr.com/forum/topic26843.html worth 5 mins to check for a split. There is nothing that can't be fixed with a hammer😜😜
Post #344178 24th Aug 2015 5:18pm
Bungal
I got a list of errors
U0401
U0402
U0403
U0416
P0101
P023D
How do I find out what these mean?
TIA
Brian
Post #344221 24th Aug 2015 9:05pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Use google, I'm sure they will come up with some answers 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #344286 25th Aug 2015 8:50am
proser
look at the info here for codes P0101 & P023D - http://www.rrsport.co.uk/forum/topic34009.html . The other codes are probably as a result.
Seems that people on here have (possibly) already diagnosed the problem - split turbo hose Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #344292 25th Aug 2015 9:07am
PaulB
Brian, it will takes you 5 minutes to check the hoses.
Do this before you investigate further.
Post #344308 25th Aug 2015 10:50am
Bungal
I have just checked the hoses.
I have a split hose,top passenger side.
I am so happy. Yes I know I'm very strange lol.
Post #344369 25th Aug 2015 6:00pm
That's where they go!
Simples Thumbs Up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #344370 25th Aug 2015 6:02pm
Bungal
Cheers guys
Would this also make the MAF's read different values.
MAF 1 about 20000
MAF 2 about 40000
Readings taken at tickover.
Post #344372 25th Aug 2015 6:06pm
Yes I would think so as you have less air going past one maf.
I would swap it out/fix it then have a look at the readings. There is nothing that can't be fixed with a hammer😜😜
Post #344380 25th Aug 2015 6:43pm
Bungal
Just need to get the hose now.
Why does work keep getting in the way. Censored
Post #344385 25th Aug 2015 6:55pm
Zirconblue
Does wrapping the split hose in gaffer tape work? (it's surprisingly strong!)
Even if you have to re-wrap it every couple of days it'll do until you get time for a proper fix.
Post #344389 25th Aug 2015 7:04pm
