Home > Maintenance & Mods (L322) > Suspension Height ?
Numb
Scotland 2005 Range Rover Vogue Td6 Java Black
Suspension Height ?
Hi All. A quick question, would enyone be able to tell me the standard height for a suspension calibration? Ether measured from wheel centre or rim,I have 20" rims. I have seen a few different measurements on this but I just want the factory height. Many Thanks.
Post #343905 23rd Aug 2015 10:36am
Thumbs Up ... - .- -.
Post #343907 23rd Aug 2015 10:50am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
As Stan Posted above, but any 02-05 you can adjust all 3 heights separately too.
Example, you could have off road height set 10 mm higher than standard and access height set at -10 mm lower than standard, normal ride height can be set to anything you want, only thing you can't touch is motorway height as that lowers what you set normal height from.
Any 06 model onwards can't do the above individually, so if off road height is 10 mm height than standard, your normal and access height will be the same. ...10 mm higher .
I knew their was a better reason getting an older model.... Laughing
Hope this helps too Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #343911 23rd Aug 2015 11:25am
Numb
Many Thanks gentelmen. Sorted, back to standard setting now. was previously set much lower, about 40mm, not ideal for me going off road, much smother on road now, as it should be Very Happy Thanks again guys. Thumbs Up
Post #343937 23rd Aug 2015 3:46pm
