Home > Maintenance & Mods (L322) > Front air bag for 2002 4.4 v8 vogue
Jock187
United Kingdom 2002 Range Rover Vogue 4.4 V8 Alaska White
Hi all need to replace the front offside airbag will these fit? http://pages.ebay.com/link/?nav=item.view&...ID=EBAY-GB
Thanks Smile
Post #343606 21st Aug 2015 12:18pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Well I wouldn't touch a remanufactured item from an unknown company especially when a brand new OEM strut can be had for only £70 more:
http://www.island-4x4.co.uk/spring-strut-f...-1253.html
As has been said in previous posts by myself and others, the front struts contain the damper and as such they should be replaced in pairs unless the other side is relatively new.
When one of my fronts went I replaced both, there was no way I would run with one brand new damper and the other on 100k+ miles.
Post #343621 21st Aug 2015 1:26pm
Delphi, link above, is OEM, don't buy the Dunlops, they don't last.... Thumbs Up Pete
Post #343624 21st Aug 2015 1:35pm
Jock187
Thanks guys, il spend the extra & get the oem, can't afford both this month, is LH the same as offside as not sure what way looking at car for LH etc?
Thanks again really appreciated
Post #343688 21st Aug 2015 9:32pm
On a RHD vehicle the nearside is the left, offside right... the struts are handed... very easy to change if you want to do it yourself... Thumbs Up Pete
Post #343696 21st Aug 2015 10:04pm
Zirconblue
OS and NS come from Near side being the side nearest the kerb, and the Off side being the side off from the kerb, as Haylands says obviously this changes depending which side of the road you drive on.
But also when ever you see LH or RH mentioned with regards to parts or the location on the vehicle, it's always expressed as if you were sitting in the drivers seat. It's the industry standard - think about it, it's where we get the terms Left hand drive and right hand drive from.
Off Side and Near side are an old method and only really used in the UK i think. For the reasons Haylands has pointed out, it would get confusing using the term OS and NS in parts catalogues and workshop manuals which have to be applicable for use in all markets.
Post #343697 21st Aug 2015 10:11pm
They could just say Port and Starboard Laughing
Off Topic Trivia of the day , airplanes on airCraft carriers are the only planes not to use port and starboard , because the are not necessarily oriented to the ship's port and starboard so they have to use left and right . 2008 MY Supercharged
Post #343705 22nd Aug 2015 4:30am
mudknight
2003 Range Rover Vogue Td6 Java Black
Hi , I'm also changing mine today , the air suspension is inactive at the moment, how do I reset it after I've fitted new unit ?
Post #344055 24th Aug 2015 7:16am
If the lights on the switches are all off it is a hard fault and you need to get it cleared with a diagnostic tool, the cheap OBD code readers will not do it...
If some lights are on then a battery disconnect should sort it (See WIKI for "how to") Pete
Post #344089 24th Aug 2015 9:43am
mudknight
Cheers for that ,, all done , didn't have to plug it in , 👍
Post #344270 25th Aug 2015 6:31am
