Home > Maintenance & Mods (L322) > brake backplates - are they really necessary anyway? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
No they aren't necessary, car will pass an mot without them.
17th Jul 2015 6:22pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Suggest a dismantle first to find out what the problem is.
17th Jul 2015 6:26pm |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 |
I ran my td6 without the front back plates for 2 years with no problems |
18th Jul 2015 6:24pm |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 |
Hi chaps,
21st Aug 2015 8:31am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
5.0 brakes won’t fit on your 05my car sir! 4 pot, 4.2 brakes will but the front calliper mounting holes won’t work with the 6 pot 5.0 brakes...
21st Aug 2015 8:40am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I think the front ones are more there as an arse covering thing by the manufacturer, I've never come across any ill effects on any car having them removed. I have seen a few cars where they've trapped grit against the disc though!
21st Aug 2015 9:24am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
A big washer should be fine to tighten them again. Although I cut them off my td6 when I had it, then was told about washers |
21st Aug 2015 10:13am |
Thanks guys,
23rd Aug 2015 5:02pm |
