Home > General (L405) > Active locking rear diff
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Ok last thing to decide on, I do use mine off road a bit. Is the diff a physical one stage lock or is it electrical clutches, is it driver operated with a switch or does the car make up its own mind, in short is it worth 450 quid? letters not necessarily in the right order
Post #343388 20th Aug 2015 6:47am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
It's variably electronically controlled and not user-selectable. First time you get stuck without it you'll be wondering if you wouldn't have with it, and when you don't get stuck you'll be pleased you saved the money.
Should also make some (small) difference on the road.
Post #343396 20th Aug 2015 8:46am
Dixy
Thanks, on the tractors, wheel spinning, engage lock and off you go, if it is totally anonymous I will always think I wasted the cash and that I am a driving god. letters not necessarily in the right order
Post #343421 20th Aug 2015 10:47am
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
Buying new it's definitely worth £450, but buying used it doesn't matter. You will be able to drive same places but with the diff it will be more smooth and with less fuss. Not all anonymous, if you have the diff view on the screen you will see when it locks up Thumbs Up Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #343422 20th Aug 2015 11:05am
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
My 2013 brochure says this option aids the cornering ability of the V8 models (not available on V6), if thats correct then yes worth £450, get every extra possible to help this thing drive better Rolling with laughter
Post #343431 20th Aug 2015 11:57am
Philip
You're flogging a dead horse, Carlos - sell it and move on.
Post #343433 20th Aug 2015 12:26pm
carlos50
I have to stick with it so am going to put some of the £10k loss I would see if selling into some wheels, stealth pack, DMS remap and fingers and toes crossed that a few replacement suspension parts will make it feel more stable such that I can enjoy it more.
I don't have this option but does the active diff improve the cornering stability as per the narrative in my sales brochure?
Post #343435 20th Aug 2015 12:32pm
Philip
Not stability as such, but you would expect a locking diff to tighten the line under power by sending torque to the wheel with more traction.
Wonder if the L405 will ever get the L494's torque vectoring.
Post #343467 20th Aug 2015 4:02pm
carlos50
And its suspension Whistle
Post #343681 21st Aug 2015 6:48pm
