Home > General > How happy are you with your 2011 TDV8?
How has ownership of your 2011 4.4 TDV8 been so far ?
Faultless in all apsects.
25%
 25%  [6]
Some minor issues all sorted.
29%
 29%  [7]
Some minor issues not all sorted.
16%
 16%  [4]
Some major issues all sorted.
16%
 16%  [4]
Some major issues not all sorted.
0%
 0%  [0]
Major and minor issues all sorted.
8%
 8%  [2]
Major and minor issues not all sorted.
4%
 4%  [1]
Total Votes: 24
You had a RRC VM diesel? Wow, not many did back then.
What was that like to drive?
Did you know that Land Rover tested a V8 diesel called the Thor project and it never came into production in the 80's, probably cos RR drivers at the time saw no need for frugality.
#beforeitstime Cool Discovery 4 HSE
Post #342385 14th Aug 2015 8:20am
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Was the V8 diesel the one they also called project Iceberg.. perhaps project Titanic would have been more apt, I seem to remember reading about it years ago in LRO they just could not get the cooling system right or some such... I bet it had a sweet sound for a diesel. 2011 Range Rover Vogue 4.4 TDV8
2003 VW Golf V6 4motion
2001 Range Rover Vogue 4.6
1982 Range Rover in VOGUE
1990 Range Rover Vogue SE
2007 Audi A6 Avant Le Mans Quattro S-Line 3.0 TDI
2007 Skoda Ovtavia 2.0 TDI L&K
2007 GSX-R 750 K7
Post #342400 14th Aug 2015 9:33am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Yes, Iceberg was the Rover V8 diesel project, Thor was when the petrol got Bosch management and lots of other changes. VM diesel was quite interesting - a separate head for each cylinder.
Tailgate corrosion - people have successfully claimed, there's a thread running somewhere.
Post #342418 14th Aug 2015 9:57am
Benfelrr
cheers, yeah this one has a spotless tailgate wheel arches etc. I do not think it has been out in the rain to be honest looking at it. 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #342435 14th Aug 2015 10:24am
Mactech
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Mine is a 2012MY but late 2011 reg.
I have a couple of seat squeaks that I must sort and I have had two instances of MFGS in 2000 miles.(Mad Fuel Gauge Syndrome!) I understand this is a fairly well known issue with the fuel gauge sender wiring. I'll see how it goes.... Confused
Otherwise, so far so good!
Craig, couldn't help noticing the similarity of our forum names Smile Do you know that nice lady Anna Grammatical?
Or has either of us been in touch with Liz Dexia? Rolling with laughter 2012MY Range Rover 4.4 TDV8 Vogue...now gone!
2007MY Mercedes C200 Estate 'Albert'
1997MY Defender 90 TDI 'Vera'
Post #342615 15th Aug 2015 3:52am
pld118
Very happy.
As CTC says, the 4.4 TDV8 is excellent. More than a good replacement for our 4.2SC. It's smooth, slick, powerful, more frugal (more time on the road and less time at the pump); and very refined with its 8 speed gearing.
The interior is subtly more up to date too.
Was only looking for a 5.0SC to replace the 4.2 but when drawing a blank because couldn't find one in as good condition as our outgoing model, as luck would have it, ended up speculatively viewing our immaculate 4.4 and the rest is history.
Superb Thumbs Up
Post #342815 16th Aug 2015 7:27pm
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
TV module replaced.
Side window trims replaced at 30 months due corrosion.
Minor corrosion on rear arches, corrected by myself by painting with POR and fitting rubber seal strips.
Arm rest worn.
Suspension pump replaced with heavy duty unit.
Upper tailgate side rubbers replaced.
Engine making 'shucking' noise at tick over, oil pump replaced.
Turbo oil return pipe modification.
Front brake hose recall.
All under warranty.
Post #342853 16th Aug 2015 9:14pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
It may be easier to ask "who hasn't?"..... Rolling Eyes 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #342860 16th Aug 2015 9:47pm
Benfelrr
Many thanks for all your inputs, was just sorting out finance and someone has swiped the car before I could get there. It will be a while before I can find another one in Green and sand around here if anywhere especially with 27,000 miles and one owner but will keep looking and keep all in mind that you advise.
Ben. 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #343086 18th Aug 2015 12:59pm
Zirconblue
I'd just be happy if i could afford one. Laughing
Post #343099 18th Aug 2015 2:10pm
pld118
Your pre sales preparation is probably the key Benfelrr?
Awareness of the potential issues and remedies and factoring them into the 'deal', including a written list of snags for the dealer to agree to sort through before collection... Thumbs Up
Post #343138 18th Aug 2015 6:31pm
Benfelrr
Indeed that would annoy me, good plan thanks! Should find a green / sand / walnut one in the next 5 years Smile 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #343143 18th Aug 2015 6:43pm
ebajema
I might consider parting with my FAULTLESS Galway Green, Sand interior, extended Burr Wood trim 2010.75 MY Autobiography 5.0 SC for the modest sum of say 50k GBP. Twisted Evil Twisted Evil Twisted Evil MY 2010 5.0 SC Galway green and sand interior!!
Post #343226 19th Aug 2015 7:16am
Benfelrr
How very kind !! Smile Think I will look closer to home though, thanks! (Assuming you have it out in Malaysia) 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #343233 19th Aug 2015 8:11am
