Home > Maintenance & Mods (L322) > Replacing the oil filter housing in an L322 4.4 v8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
If the pipe in the middle of that is missing then it's not working as a filter, the oil will just go straight through it......
17th Aug 2015 10:13pm |
Bagus Member Since: 14 Apr 2014 Location: London Posts: 196 |
Cheers. It looks like its only secured on with the 2 screws at the top although I need to take a proper look at it in the daylight. |
17th Aug 2015 10:20pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Assuming the fittings are the same as the earlier ones, the rubber cotton real mounts will fall to bits when you undo the nuts. I drilled out what was left of mine and replaced them with some M6 bolts with a couple of bits of fuel hose as a spacer. The new mounts are £7 each from Land-Rover, and apparently they all fail!
17th Aug 2015 11:56pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
when the previous guy changed the oil, he obviously threw it out with the filter. i think it unscews and you then pull it out of the filter, and screw it back in. |
18th Aug 2015 4:00pm |
you're supposed to just be able to pull the filter off of it in situ, as you do the filter releases a valve in the bottom to let the oil drain out of the housing.
18th Aug 2015 4:23pm |
and possibly did more harm than good, leaving the oil filter 'bypassed' - for a full service term. |
18th Aug 2015 4:32pm |
exactly, but saying that if the engine is still ok, then while it's probably shortened the engines over all life, it might only mean the bearings fail at 300k instead of 700k.
18th Aug 2015 4:52pm |
What's confusing me most is why they indie didn't mention this last year when they serviced the car. No one else has worked on the car. The service this year was just an annual oil service (only done 3500 miles in the last 12 months) but I paid good money for the major service last year.
18th Aug 2015 8:58pm |
went i changed my filter, it fell to bits, and the plastic end cap was stuck in the bottom. I did try removing the centre pipe to get the end cap out but it seemed pretty solid.
18th Aug 2015 9:02pm |
