Home > Technical (L322) > Smokey tdv8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8282 |
Take it back....????? Pete
16th Aug 2015 8:43pm |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 |
Is it the 4.4 TDV8? If so it will be the turbo oil return pipe. This needs to be modified and is covered by various threads on here. Unfortunately if the car is out of warranty JLR will probably not cover the cost and it is a big job. |
16th Aug 2015 9:00pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
His profile says 2007. |
16th Aug 2015 9:02pm |
16th Aug 2015 9:04pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
If its a 3.6 then check for split hoses. But as said above! Iff you have just purchased it, why not take it back and ask for it to be rectified? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Could be something simple like a filthy/blocked air filter could be something major as already pointed out.
16th Aug 2015 9:12pm |
Gunnerboy Member Since: 16 Aug 2015 Location: Hove Posts: 9 |
Checked air filter replaced it as was dirty and both hoses from inter cooler were split replaced them no more smoke onto other jobs!😟 |
26th Aug 2015 9:07pm |
26th Aug 2015 10:09pm |
That was a result then.... Pete
26th Aug 2015 10:31pm |
