![]() | Home > In Car Electronics (L322) > Replacing the twin subs |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
wouldnt a 2005 vogue have the logic 7 system anyway? (which i believe has one big eliptical sub in the boot) |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 ![]() ![]() ![]() |
Mines a 2005 but pre facelift |
So's mine (a 2005 model year) on a 54 plate - still has the touch screen and logic 7 all 2005 model year cars did. Unless yours is actually a 2004 model year that sat in a dealership unregistered for ages? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
He has the MK4 sat nav upgrade, so can't be touchscreen.
yes thats definatley what i am saving for, got a few things to pay for before that though like the digital tv upgrade! |
Perhaps Baris can do you a discount if you do both together.....
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
WOW ![]() Have you ever listened to a Logic & system in 05> or pre 05AB models? That should elevate your issues ![]() |
Cheers Craig. I get where you are coming from. Mine was like singing through a blanket as standard. The bm54 stage 2 amp upgrade is very good. Really brings it to life. Can't believe the standard speakers do what they do.
Have fired an email off to carphonics to ask if they would do any kind of deal if i send in the bm54 and the tv unit at the same time, heres hoping |
Well bm54 and TV sent off today to baris special d so hopefully won't be long till I can hear what all you guys are raving about |
I had the stage 1 first, and was impressed, so going from stock to stage 2 in one go will be quite a wake up call.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
how does this effect cars that have the separate DSP amplifier like mine? if your upgrading the amps in the BM54 radio unit but not the DSP amp that is actually powering the speakers is the difference really that noticeable?
The amp is in the BM54 radio module not the DSP. The dsp just processes the sound. What they tend to call them is technically wrong, but I stay quiet, but can be confusing.
I have dsp also. Dsp can only process sound from the quality of the line it receives, so improving bm54 power output will give the dsp a much better feed and better outcome in sound overall.
