Home > Maintenance & Mods (L322) > Slow to warm up / not getting there |
Sorry to resurrect an old post, but did you ever get to the bottom of this?
14th Aug 2015 7:13am |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 601 |
14th Aug 2015 7:18am |
Had a new thermostat last week...
14th Aug 2015 9:37am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8222 |
I'd get the belt changed and check the belt tensioner is working correctly... It could seize up when cold and then free off when sat in a warm engine bay while your at work and be fine on the way home.... Pete
14th Aug 2015 10:51am |
When I changed the belt on my 4.2 SC, is also changed the tensioner roller. Same issue although in Nigeria the engine was warming up fine . The tensioner roller bearings seize up over time and that is causing the squeal and belt wear. MY 2010 5.0 SC Galway green and sand interior!!
14th Aug 2015 11:39am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
I believe Ray just changed the thermostat and was ok after, the old one was sticking. If it dont work.......burn it!
14th Aug 2015 11:47am |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
What is described is typical of the thermostat sticking open, seems quite common on the jag engines - first thing I did when I got my 4.2 sc. you need to loosen the tensioner to remove the belt to get access so if the squeel has Coe bout after that something isn't right. |
14th Aug 2015 12:09pm |
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 |
What is the cause for the thermostat to be "sticky" or "stick open"?
14th Aug 2015 6:00pm |
The thermostat is either controlled by wax or sprung metal that when hot opens a valve (normally plunger based) and directs water into the radiator circuit. Over time the spring or wax can tire / break or corrosion can set in reducing the motion or moving parts, or something could get lodged in the valve keeping it open.
14th Aug 2015 6:22pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
exactly, the thermostat just wears out basically. They're old and generally reliable tech, but they don't last for ever.
14th Aug 2015 6:43pm |
Thanks guys. |
15th Aug 2015 6:10am |
When in doubt, I always replace a thermostat. Not worth the hassle of opening up the housing and then testing it, finding out it is not OK and buying a new one and putting it in. Just easier, buy a new one, drop it in and done. MY 2010 5.0 SC Galway green and sand interior!!
15th Aug 2015 6:13am |
