![]() | Home > Maintenance & Mods (L322) > Mercedes Sprinter Jack, tempted? but unsure about the top... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi all, I'm plotting and scheming again |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35527 ![]() ![]() |
is this the kinda thing you want to do?
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
http://www.disco4.com/forum/topic89625.htm...p;start=90
http://www.disco3.co.uk/shop/sprinter-jack-washer-kit-p53.html
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 ![]() ![]() ![]() |
How about this http://www.ebay.co.uk/itm/Aluminium-Kart-S...1e7e114d24
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
I'll be interested if you end up making some |
In the end I wouldn't use one. They aren't really rated for the use of a disco, ssrr or ff and a few have had them fail iirc.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
The top horn is very easy to file and either to weld on a plate like what I did or just place it on, jacks the car up a treat, BTW Paul the part you posted arrived today |
When you Jack the rear id say more like 500kg is on each wheel and more like 800kg possibly more up front, but having a jack that is rated well above the ff total weight makes lifting of it a sinch.
If I have to Jack up my ffrr I use my 2.5 ton rocket lift trolley jack, but if I'm driving down the road and find myself in a situation where I have to jack the car up, it would only be to change the wheel, cos anything else can wait until I'm home and I can use the trolley jack. There is No way I am going to smash the rear of my ffrr up carrying a trolley jack around, although I could tow it |
Miggit just put your old school woodwork skills to the test and make it from wood, it's soft so won't damage the soft plastic pads on the ff either 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Nah, a small 1/2" thick piece of wood with the correct size circle indented into already would be fine, at worst the wood will just compress.
