Home > General > How happy are you with your 2011 TDV8? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
A couple of silly issues with mine.
11th Aug 2015 11:30pm |
Oh and absolutely streets ahead of my 4.2 sc & both my 3.0 & 3.6 derv models. SUCH a leap forward in technology, sound/quiet & comfort levels |
11th Aug 2015 11:34pm |
Herdwick Member Since: 05 May 2010 Location: Lake District, Cumbria. Posts: 36 |
I put for minor issues, I have had 4 x new starter motors. (A common fault) and an intercooler pipe split. A modification to the air con pipes seems to have helped to cure the problems with the starter motor,
12th Aug 2015 9:53am |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 294 |
Thanks guys , much appreciated. ! I Looked at the car this morning, it is pretty mint! 2011 Range Rover Vogue 4.4 TDV8
12th Aug 2015 12:22pm |
Forgot about the intercooler pipe i replaced too
12th Aug 2015 12:38pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Mine is a 2011MY but is the 4.4.
12th Aug 2015 1:02pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2563 |
Fixed - rear and side window trim corrosion; hesitation (software reflash); starter motor; foam filler block in door shut (twice).
12th Aug 2015 3:43pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1014 |
I get frequent low battery warnings on my Mini Cooper S. Apparently, it's because I don't drive it enough. It does lots of short journeys with SWMBO. Never had it on the RR or RRS, but only do longer journeys in those cars. |
12th Aug 2015 4:31pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Hi,
12th Aug 2015 4:38pm |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
I have only had my car for 6 weeks, and after my TD6 it is a revelation. Lots of power, smooth, quiet. Nothing has gone wrong so far, but talking to the previous owner, he had to have the turbos replaced under warranty. and had an electrical problem with the suspension sorted. 2011 Vogue TDV8 4.4
12th Aug 2015 6:21pm |
Bagus Member Since: 14 Apr 2014 Location: London Posts: 191 |
I've been thinking about upgrading to one of these but my 2002 4.4 petrol still keeping running sweetly. Seems like there have been quite a few problems so maybe I'll run my V8 into the ground before I change. |
12th Aug 2015 8:30pm |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
I'm in a similar place with my 2002 V8...but took the plunge and put it on ebay now so looks like a 3.6 or 4.4 TDv8 will be (hopefully) imminent |
13th Aug 2015 12:30pm |
Ahh, that may be tempting fate sir |
13th Aug 2015 10:55pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3760 |
Had. 4 rr over last 30years. Started with 2.5vm diesel so , then 2.5td P38, just traded up from Td6 Vogue.I have kept each one until 100k miles or 9years. Just hoping to do same, but not happy just spotted first signs of corrosion on upper tailgate bottom right corner. Anyone made corrosion warranty claim? |
14th Aug 2015 7:59am |
