Home > Maintenance & Mods (L322) > My Air con didn't work, so I fixed it! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi all, I am going to be shot down in flames for posting this, and I don't care cos my A/C works
11th Aug 2015 8:22pm |
And It Begins..................
11th Aug 2015 8:47pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Nothing wrong with what you've done, topping up a system is fine, it's discharging it to the atmosphere that's not very kind.... and illegal
11th Aug 2015 10:48pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
I did it on an old Fiat worked fine for the 18 months I kept it. As a diy solution the kit works well, perhaps not the best way to do it but it does seem to work. Took my mums Citroen to Kwikfit though, £45 for a drain and refil. |
11th Aug 2015 11:00pm |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
Whats wrong with my comment, I'm just stating the way in which the sealer works. You remind me of a young me, not much younger mind, perhaps even a little older! |
12th Aug 2015 6:37am |
As I predicted in the opening line of my post And I know that it reacts with air, I want it too, if it didn't come in to contact with air then I wouldn't have had a leak But in all fairness it does say that you need the compressor to run before you put the sealer in the system, and that you must top up the system after to stop the low pressure port from blocking. So the trick is to put enough gas in to get it all working, but leave enough room to get the sealer in and a top up to flush the port. Which is real easy on a 'ang 'over as they have a really big A/C system Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
12th Aug 2015 9:39am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Well done....
12th Aug 2015 9:55am |
Doesn't the gas bottle you get from Halfords contain a leak sealer as well as gas? Mine did. |
12th Aug 2015 10:04am |
Now your asking, why does someone always have to ask the really difficult questions......
12th Aug 2015 10:14am |
Yes, the gas has some leak sealer in it, but only says it's good for 'O' rings, Super Seal will also deal with cracked metal parts as well
12th Aug 2015 10:21am |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
But is it ice cold now? 2003 Range Rover Vogue 4.4 on Gas
12th Aug 2015 12:01pm |
Yes, but it isn't blowing clouds in the car now, like it was a month ago Yesterday I couldn't spell Engineer... Today I are one!
12th Aug 2015 12:08pm |
On my 4.2 the entire system was changed apart from the cabin cooler and a year later we had to top up coolant again . So big bill AND still not fixed. MY 2010 5.0 SC Galway green and sand interior!!
12th Aug 2015 1:33pm |
The gas doesn't have leak sealer in. It just contains pag oil. Which the seals will absorb. Leak seal usuall causes issues. Why not just change the problem o ring instead? That's why no main dealer or ac engineer will use it. Just make sure you put a sticker on stating its in there. It up ac test equipment.
12th Aug 2015 6:52pm |
