Home > Technical (L322) > How do I get access to these bulbs
SCPB
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I have changed all my interior lights over to white LEDs and just have this one to change plus the same one on the passenger side which is integral to the glove box.
Before I cause any damage, do the lenses come out from the front, to access the bulbs, or does the airbag panel on the drivers side and the glove box trim on the passenger side have to come off. Thanks in advance. 2010 5.0 SC Autobiography
Post #341837 11th Aug 2015 1:01pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
The one at knee height pops out from the front, it just needs a bit of gentle persuasion with a fine screwdriver or similar. Just be careful now to damage the surround. I took the side panels off to try and do mine but you can't get at that from the side.
The golf box is a bit of a pain as you have to undo all the torx screws and drop the front down but even then I struggled. I am sure someone with a bit more,knowledge will be along with the correct method for this one.
Post #341840 11th Aug 2015 1:15pm
SCPB
Many thanks, yes I tried to take the side panel off, on the drivers side, but thought that I would ask before I made a hash of it. I am not sure if it is the same on all L322's but the shin airbag is in the same panel. 2010 5.0 SC Autobiography
Post #341847 11th Aug 2015 2:27pm
SCPB
In case it helps someone else, the bulb on the passenger side is actually changed in the same way as the drivers side, it just pops out, well certainly on the 2010 model. This is what it looks like.
Post #342355 13th Aug 2015 11:34pm
thats helpful Thumbs Up ... - .- -.
Post #342387 14th Aug 2015 8:33am
