Home > Technical (L322) > Why is service indicator on? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
To be fair I don't think it's just about Land Rover franchises. It's more just about the motor trade in general. I mean car dealers have never had a particularly great reputation for honesty. There are good and bad ones franchised or not, but it pays to go into it with an open mind but a degree of suspicion the same as you would with a backstreet car dealer.
9th Aug 2015 6:05pm |
9th Aug 2015 7:48pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Its quite difficult to forget to re-set the service indicator on a 2010 + (if you have done the service properly that is!) as you have to plug the tool in to read any fault codes as part of the service and it should promt you to re-set, and its the first thing on the service schedule!
10th Aug 2015 10:57am |
On the other hand, most dealers have more service bays than they have diag machines, so if the machines are occupied the tech might get on with the service while waiting for one of the machines to become free. Then forget to plug in the computer afterwards.
10th Aug 2015 11:12am |
Pity you can't check the oil but you should be able to see if the oil filter, oil pan plug/seal ring etc. have been handled recently. Even with the low mileage I bet that you can still see whether they were done recently.
10th Aug 2015 12:19pm |
The problem with checking if the oil & filter have been changed is, most garages can suck out the oil through the dipstick tube, so the sump plug might never have been touched (i'm not saying it's the best way to do it).
10th Aug 2015 12:31pm |
Isn't the TDV8 "dipstickless" (no pun intended Ryan) ? MY 2010 5.0 SC Galway green and sand interior!!
10th Aug 2015 12:35pm |
A lot of cars are these days, but many of them still have a tube with a cap on them - crazy! |
10th Aug 2015 12:37pm |
Like I said earlier, even if there were evidence of the oil and filter being changed - and there are little witness marks, I would change them again anyway, as you don't know the quality or the grade of the oil that has been used and we all know how critical it is with these engines.
10th Aug 2015 12:51pm |
That maybe true, but if the book does have a stamp, i'd want to make sure it had actually been done, you've paid for it one way or another. You can always ask to see the drum/bottles that the oil came from if a garage does it. |
10th Aug 2015 1:06pm |
A detailed service invoice from April shows filters changed, oil changed, front brake pads and discs changed etc. Must be an oversight around the reset... |
11th Aug 2015 6:06pm |
I would have thought so, checking a couple of the easy to get to filters would confirm that as far as practical. |
11th Aug 2015 8:46pm |
