Home > Technical (L322) > 2011 TDV8 4.4 juddering issue |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Steve, would it be an idea to get another garage to take a look, fresh eyes and ears????
9th Aug 2015 10:23am |
Sh55123 Member Since: 31 Dec 2012 Location: Surrey Posts: 7 |
My MD is Harwoods of Croydon - not impressed either, and I too thought that the main dealer extended warranty would cover investigation work, but they tell me not.
9th Aug 2015 10:28am |
Ryan from LR customer relations will investigate the claim for you.
9th Aug 2015 10:44am |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
if your cars under warranty ,you shouldn't pay a penny ,I'd be livid.
9th Aug 2015 10:52am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
Sounds a bit like a torque converter issue.
9th Aug 2015 11:03am |
Thanks for the tips gents - hugely appreciated! I will look up Ryan and contact him as you suggest.
9th Aug 2015 11:05am |
I suspected torque converter shudder too, but was hoping they might have suggested that too.
9th Aug 2015 11:08am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2501 |
Any chance that the park brake is sticking, possibly being out of adjustment? |
9th Aug 2015 11:23am |
I suspected that too, but it doesn't do it while coasting in either forward or reverse when in neutral. I have tried at various speeds, and no sign of it when in neutral, all the way to slowing gradually to a stop on a flat surface. |
9th Aug 2015 11:29am |
Brake caliper sticking (rears usually) could also be a problem. Easy to diagnose by feeling the wheels after a short drive. The wheel with the sticking caliper will be hotter. Since it has been going for a while (if it is a caliper) the bearings may now also have overheated a few times.
9th Aug 2015 11:32am |
I don't think it can be brake related, as it does it in reverse when stone cold, and doesn't do it at all in neutral.
9th Aug 2015 11:47am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I thought that my torque converter was on it's way out again, even though it was only 14 k old, it has turned out to be 2 half dead injectors, mine only really showed up under gentle driving conditions, and the full on performance was not affected in the slightest.
9th Aug 2015 11:48am |
Try this
9th Aug 2015 11:54am |
FYI warranty will normally cover mechanical brakedowns, and not ware and tare, which is what I suspect the dealer is hoping for. Ie if it brakes they will replace it, but if it wares out then it's down to you. I would talk to your local Bosch agent, as the shuddering that your describing sounds very familiar to me, and even if it's not the engine, I'd rather pay the £65 per hour than stealers prices. And bare in mind that if your injectors are bad the stealer will only replace the with new, at LR prices, I bet that you can get all the injectors cleaned, test and repaired (if needed) for the cost of one injector from LR and have change Yesterday I couldn't spell Engineer... Today I are one!
9th Aug 2015 12:07pm |
