Home > Maintenance & Mods (L322) > Air compressor advice
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Had all the bongs yesterday, Air suspension, HDC inactive etc. Have done a battery reset to no avail, all lights out on the dash, car sitting about an inch lower on the nearside, anyway, had a new compressor about 3 years ago and both front bags last MOT (10 months) so thought of buying the compressor repair kit from bagpiping andy. has anyone done this and if so was it worthwhile,
thanks in advance Thumbs Up
Post #341303 8th Aug 2015 7:07pm
some info in our wiki.. Thumbs Up ... - .- -.
Post #341305 8th Aug 2015 7:10pm
Rosco
Stan have been through the Wiki, was really asking if anyone had used this compressor kit and will give it a go myself Thumbs Up
Post #341309 8th Aug 2015 7:49pm
this chap did,
http://www.fullfatrr.com/forum/topic29979....ressor+kit ... - .- -.
Post #341316 8th Aug 2015 9:02pm
Rosco
Cheers Stan, will give it a go Bow down Thumbs Up
Post #341318 8th Aug 2015 9:22pm
djharm
Netherlands 2002 Range Rover Vogue SE Td6 Java Black
I used the kit from Meerbusch, worked out great. It also comes with a new piston. cars on the side;
Audi A8 W12
560 SEC AMG Widebody '86
500 SE '86
Post #341732 10th Aug 2015 9:41pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I fitted one of those kits from Andy when I got my car. The Car was off the road for a month whist I attended to many jobs. I put the kit in only as a maintenance item, the compressor seemed fine but as far as I knew was the original so fitted a new seal to be safe. Easy to do and no dramas. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #341757 11th Aug 2015 6:33am
ebajema
Three years with a new compressor seems a bit short. Have you looked/listened for system leaks ?? Checked the valve block ?? Rear bags ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #341758 11th Aug 2015 7:01am
Rosco
Update - 2 days of no rain and a bit of heat (not like you southerners) and all bongs disappeared and suspension back to normal????
Could it be a damp BCM, I had that before and it set all the alarms off and lights on. Thumbs Up
Post #342111 12th Aug 2015 8:12pm
Question, is there a kti for the new pumps at all yet? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #342262 13th Aug 2015 4:10pm
