![]() | Home > Technical (L322) > Lambda/Oxygen Sensors |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1369 ![]() ![]() |
they should last for about 70,000 miles without needing to be changed out |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8567 ![]() ![]() ![]() |
make sure you/they fit genuine or OEM, there are cheap pattern ones out there that don't last... Pete
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
Why do you need to replace it so often - are there error codes that indicate that and what are the symptoms |
georgedb Member Since: 12 Apr 2015 Location: Gauteng Posts: 82 ![]() ![]() ![]() |
@ Haylands: Thanks. I think here in SA you can only get them from LRSA.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It depends what is killing the sensors.
@ Zirconblue: Will have to have to exhaust system looked at for leaks then as you say the cats. |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Assuming 2 lambda sensors, are they both the same part number, if so, you could try swapping them over. I had an issue on another car once with them and it was simply a poor connection on one of them. On that car,no feedback from a sensor defaulted to 100% oxygen and so the ECU was basically assuming at least 50% flow all the time causing the car to run 'rich' on fuel (as I'm told the ECUs used to just take the readings from the 2 sensors and divided it by 2 to get the average oxygen flow rate - they may be more advanced now though). So basically , if I disconnected them both completely, the ECU assumed 100% (2 x100 / 2) air flow and the engine would run very very rich. May be worth checking the connection pins. LRs may work totally differently of course. Steve
@George. What error codes does it show when you plug the diagnostic tool in. Does these errors include "multiple misfires"? Is the car's engine performance reduced when the EMS light is on. Is the lumpy idle a misfire or not?
@Trev PM sent.
So took the truck in to an Indie past Friday. They hooked up the more upmarket OBD tool and picked up a low voltage error on the rear sensor for bank 2. Swapped right to left and cleared all errors. So will monitor the new setup and see if error returns. |
Did this also resolve the lumpy idling issue? |
I would say yes; but did not drive too much this past weekend. But on startup yesterday; this AM and this arvie I did not notice any lumpyness or roughness on start-up at idle speed. |
