Home > Maintenance & Mods (L322) > Replacing Sensors still!
Page 1 of 3 123>
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Still trying to find out how to get to the rear sensors - my faulty one is the same as previous posts , rear left hand side - so possible wiring chafing?
Can you get to them by removing the rear bumper step trim? if so how do you remove it? I have been looking at it and it doesnt give any indication as how it is fitted or removed. CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #34002 27th Oct 2010 1:50pm
just looked on RAVE and it appears that the sensors just push fit in.....other than that i dont know .. ... - .- -.
Post #34004 27th Oct 2010 2:11pm
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
i need to know too, rear right not working on mine !!!!
Post #34015 27th Oct 2010 4:13pm
dan_uk_1984
This is why no one can find anything using search. 3 topics for one question Mad
Post #34017 27th Oct 2010 4:18pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
you have to remove the rear bumper to get them out, they clip into the bumper with 3 tabs. 2002 td6 vogue, 06 supercharged facelift
Post #34033 27th Oct 2010 5:39pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Replacing Sensors
I own a 2002 L322 and had all the rear sensors replaced without removing the bumper. The sensors were playing up and I was getting long beeps. I expected the bumper needed removing with a big labor bill for the privilege but to my surprise the garage that did the job had just purchased a very clever tool to remove them from the outside of the bumper which also kept the cost down.
The sensors now work perfectly on the rear and glad the PDC ECU was ok, I have left the sensors black plastic due to the coat of paint sometimes being the issue especially if moisture gets behind and bubbles the paint as it did which contributed to the failure.
I now need to do the front but it’s a different fault as they are all completely dead, no error, sound or clicking so could be the loom damaged so this WILL be a bumper off job……………oh joy……..just need to learn how to do that……… Big Cry
Post #34190 28th Oct 2010 11:04pm
fyi,there is a thread showing how to remove the front bumper. ... - .- -.
Post #34199 29th Oct 2010 8:10am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Just for some more info. If the wiring loom is damaged expect it to be on the drivers side front corner and it will need to be repaired as it is part of the main engine bay loom. Therefore lots of money... My money is on your ecu being defective but have the configuration checked to ensure the front sensors are active as they can be shut off manually. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #34218 29th Oct 2010 10:44am
netsonic Steve
So it’s possible the ECU can work fine for the rear but not the front, not sure the best way to test and eliminate whether it’s the loom, sensors or ECU although there is a 2003 ECU on e-bay for £50 with 17 hours to go...........tempting. In reference to the front being shut off manually this is assume would be done through the dealer computer as an option, this I am sure was not done as this did work when I first had the RR but then one day the front just stopped although I can’t recollect exactly when.
Is it possible to swap the front and rear leads into the ECU so I can test a known working out port on the ECU and plug in the suspect wiring to the sensors...........
Post #34280 29th Oct 2010 2:47pm
dan_uk_1984
You cant swap front/rear unfortunately. I thought of this but the plugs are moulded differently so you cant make this mistake.
Let us know what you find. I have the same issue with the fronts not working...
Post #34283 29th Oct 2010 2:53pm
thinking aloud, i wonder if it could be the switch on the dash thats the problem for you two...maybe dodgy wiring behind it? ... - .- -.
Post #34286 29th Oct 2010 2:57pm
dan_uk_1984
Doubt it, as the rears work?
Post #34287 29th Oct 2010 2:59pm
but doesnt the switch ,only switch off the fronts when you need to.. ... - .- -.
Post #34290 29th Oct 2010 3:03pm
dan_uk_1984
No, it switches both off or on. The HSE doesnt have front sensors but still has the switch etc.
Post #34294 29th Oct 2010 3:12pm
if you mean my hse then yes it does have front sensors and i can switch the fronts off and still have the backs working..[i think Neutral Neutral ] ... - .- -.
Post #34295 29th Oct 2010 3:16pm
Page 1 of 3 123>
