Home > In Car Electronics (L322) > Ignition controlled live
proser
Whilst looking through the forum to find any info on fitting a dash cam and hard wiring into an ignition live. Really couldn't find anything that definitely stated which fuse in the front was used, so I looked through the wiring diagrams and done some testing with a multimeter and found that fuse 5 is controlled by the ignition.
I also think that fuse 2 & 8 are as well but didn't test them.
Hope this might help someone on here in the future. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #339985 30th Jul 2015 8:30pm
thanks mark...i have noticed that fuse numbers and their functions differ quite a lot through the model range.. ... - .- -.
Post #340009 30th Jul 2015 9:55pm
proser
Stan,
The wiring diagrams I referred to are on here, which seem to be copyright 2001, and mine is a 2007 and fuse references seem to be the same. Regards
Mark
2012 Westminster
Post #340011 30th Jul 2015 10:00pm
johnboyairey
be sure to update us with the fuse you used for your dashcam, and what year etc. as i tried to use one recommended, on a previous thread, (piggy back on i think either 7 or 13) and it affected the steering badly. (steering angle sensor i think. )
Post #340087 31st Jul 2015 10:36am
^ Plug you piggy back connector into an un-used fuse position then you won't affect anything.
Plenty of un-used ignition controlled positions available. Thumbs Up
Post #340091 31st Jul 2015 10:47am
proser
I used fuse 5 in the front. Labeled for diagnostics port and transmission - no adverse affects yet.
from a 2007 TDV8
I have just tried all the spare slots. Some do not have connectors for fuses and the ones that do are not perm or ignition live.
HTH someone. Regards
Mark
2012 Westminster
Post #340122 31st Jul 2015 2:49pm
