![]() | Home > Maintenance & Mods (L322) > 2008 TDv8 - Not a good start |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6762 ![]() ![]() ![]() |
hmm, smacks of a dodgy battery |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Sounds like you simply ran her out of fuel sir |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
HDC inactive and vehicle speed sensor could be related as the speed sensor for the speedo is the rear left abs sensor this would also play havoc with your trip recorder, and the abs sensors are used to control speed whilst using HDC , low fuel pressure then as your recovery bloke says it may just be out of fuel , I'd check the battery as well because as soon as the battery starts playing up it can throw up all sorts of weird and wonderful faults one of the main ones being HDC inactive . |
MAZI Member Since: 14 Dec 2013 Location: EDINBURGH Posts: 15 ![]() ![]() |
Seems a lot of problems for dodgy battery! Also the garage connected a fully juiced up booster pack when reading the codes and trying to start her. �20.00 diesel also added.
I used to get hill descent inactive message on my old TD6 if I left it parked up a few days.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
as Craig says^^^
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 ![]() ![]() ![]() |
+1 for no diesel.. I done exactly the same thing the second day I had mine.. The car hadn't been used much before I got it, and One of the sensors in the tank was sticking on full, the gauge told me I had half a tank all the time, next day I took it out,car started shunting, and then boom, car stopped, spec prog off, HDC inactive, wouldn't start ... Confused me when it happened, I'm sitting there thinking it seems like no fuel, but the gauge says I have half a tank.. After a bit of research, I found out there is a valve like a tyre valve under the plastic engine cover, fuel bleeder , my friend spun the car over whilst I held the valve down with a door key, and no fuel came out.. Got a can, filled it, diesel in, then held the valve down whilst turning it over, 15 secs later and fuel started coming through, and car started..
OK Day 2 update.
As last post.. You need to bleed the system.. Air in a diesel system is bad news.. Ya can't get away with it like you could a petrol..
Do you have a picture by any chance? |
I can get one now if you'd like, but it's dark, not sure how good the picture would be..
Thank you so much. |
OK, I've circled the bleed valve in red, just next to the oil cap.. You don't even have to take the engine cover off, just lift the front up.. Have someone hold the valve down and turn the car over to purge the system of air.. When fuel comes out, let it go, you're good for takeoff
Thanks again. I owe you big time if this works. Thanks for the effort at this time of night. |
