Home > Technical (L322) > Quick iid tool question.
J90
France 2006 Range Rover Vogue Td6 Java Black
I'm going to use mine for the first time tomorrow. The instructions state put the car in park and ensure the parking brake is not engaged. Am I correct in assuming that the parking brake is what I call the handbrake?
Ta.
Post #339782 29th Jul 2015 7:52pm
Yes.... Thumbs Up
Take note of all the faults stored, then clear them, then go for a drive and check again... it will surprise you how many old faults are left in the system.... don't panic, we all have them.... Thumbs Up Pete
Post #339785 29th Jul 2015 7:56pm
J90
Thanks Haylands Thumbs Up
Post #339786 29th Jul 2015 7:59pm
dont forget to keep the engine running.. Thumbs Up ... - .- -.
Post #339788 29th Jul 2015 8:06pm
And the hand brake off Thumbs Up Bow down Thumbs Up
Post #339792 29th Jul 2015 8:12pm
J90
OK gents, engine running, handbrake off Thumbs Up
Post #339832 29th Jul 2015 10:32pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
The IID Tool - a hypochondriac's best friend
I have also just received my IIDTool (thanks to Dan at Duckworth Landrover for good price and quick delivery). It does look to me like giving a hypochondriac a medical textbook because I am finding faults I didn't know I had. First off when activated I read the stored faults of which there were many, some going back years! The car has only ever been serviced at the main dealer - surely they read and clear faults at each service?
Anyway I cleared the faults and stopped the engine. A while later, I tried reading faults again, and two had recurred (and keep recurring).
IPC Instrument Pack 0128-00 (2E) lost comms with parking brake module
DDM Driver's Door - central locking module circuit short to battery or open cct
AAM - Audio Amplier B1A02-13 and B1A01-13(2F) Speaker 1 and 2 circuit open.
Now these systems seem to be working fine (haven't checked all speakers though) The parking brake works OK and central locking works too.
So what is going on here - how can I run further checks, or should I just forget about it?
[/list] 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #339922 30th Jul 2015 2:58pm
dingg1
just forget about them
I think most of us have the speaker codes all the time with no detriment to the system , parking brake is a comms issue , still works ok - central locking still working , just enjoy driving it IMO
Post #339924 30th Jul 2015 3:05pm
J90
I've used mine today for the first time and hopefully cleared a lot of faults. However I could not understand most of the entries in the CCF. I've looked on the Gap website and although it has some form of list of CCF thingies does anyone know where I can obtain a full list in understandable language of all the possible things (if fitted) that can be changed or altered.
For example what does ' Sat on the move' Yes or No mean?
Post #339986 30th Jul 2015 8:30pm
Probably gives the option to program the sat nav on the move..
not seen a list anywhere, just try them out and see what happens..... Thumbs Up Pete
Post #339990 30th Jul 2015 8:41pm
Lost for Words
I wouldn't...
If you don't understand them, you probably don't need to change them, and if you don't need to change them, don't.
It's only if you change/add parts etc. or for a few other enablements (like SNOTM) that the CCF needs to be changed.
GAP filter out the useful/tested CCF options; a typical full version (my as-built) looks like this:
    Body Style (text taken from database) Normal
    Changed Roof Structure Fixed roof structure.
    Coil Springs Not fitted / Disabled
    Delivery Mode - Reserved Not fitted / Disabled
    Dynamic Response Module (DRM/ARC) Not fitted / Disabled
    Four Corner Air Suspension 4 corner air suspension is fitted.
    Left or Right Hand Drive Right hand drive
    Model Year 2006 model year.
    Sliding Roof Fitted Fitted
    Split Tailgate Split tailgate is fitted.
    Steering Angle Sensor Steering angle sensor is fitted.
    Steering Angle Sensor Orientation Sensor mount - normal.
    Suspension Delivery mode Not fitted / Disabled
    Terrain Optimisation Fitted Terrain optimisation is fitted.
    Towing Ball Fitment change Not fitted / Disabled
    Two Corner Air Levelling Changed Not fitted / Disabled
    Two Corner Air Suspension Not fitted / Disabled
    Vehicle Armour? Non-armoured vehicle
    Vehicle Brand Land Rover
    Vehicle Identification Number (VIN) SALLAAA136A****** (VIN removed)
    Vehicle Model Discovery 3 [LR3].
    Wheelbase Least significant byte 68
    Wheelbase Most significant byte 11
    Auxiliary Fuel Burning Heater Fitted
    Climate Disabled
    Climatic Seats Country 0
    Electric Windshield Defrost Fitted
    Front Climatic Seats (Heated and Cooled) Not fitted / Disabled
    Heated Rear Screen Fitted
    Heated Rear Seats Not fitted / Disabled
    Heated Seats Fitted
    Hevac System Type ATC
    PTC Not fitted / Disabled
    Park Heater Not fitted / Disabled
    Rear Climate Control System Fitted
    Rear Climatic Seats (Heated and Cooled) Not fitted / Disabled
    Seat Material Leather type 1 material
    Smog Sensor Not fitted / Disabled
    AM / FM Disabled
    Accessory Phone Disabled
    Audio Amplifier Type Fitted AUD4
    Audio System Country / Region Configuration Europe
    Audio Visual Audio Input Not fitted / Disabled
    Audio Visual Audio Ouput Not fitted / Disabled
    Audio Visual Auxiliary Input Installed
    Audio Visual Fitment Audio visual 1 not fitted
    Audio Visual ISO1394 (Firewire) No
    Audio Visual USB 1 No
    Audio Visual USB 2 Not fitted / Disabled
    Audio Visual Video Input Not fitted / Disabled
    Audio Visual Video Output Not fitted / Disabled
    Bluetooth Bluetooth enabled
    CD Unit Type Multi-disc CD player.
    CD player Type Multi CD mechanism is fitted.
    Cellular Telephone Cellular telephone docking station, with bluetooth.
    Cellular Telephone Voice Language UK English
    Centre Speaker Undefined
    Companion Cam Error No
    Companion Camera Supplier Test Mode No
    Customer Personalisation Fitment Customer personalisation is fitted.
    Customer Personalisation Mode Driver
    DAB Disabled
    Digital Audio Broadcasting Receiver (DAB) Fitment Not fitted / Disabled
    Digital Audio Broadcasting Receiver (DAB) Type Receiver variant 1 fitted.
    Digital Audio Receiver Configuration Remote digital audio receiver not fitted
    Diversity Antennea Fitment Antennae fitted with diversity
    Entertainment Package Undefined
    Entertainment Reserved 1 Parameter not used.
    Entertainment Reserved 2 Parameter not used.
    Entertainment Reserved 3 Parameter not used.
    Entertainment System Bus Type MOST based system is fitted.
    Front Auxiliary Disabled
    Global Positioning System (GPS) Receiver Type Fitted with global positioning system (stand alone multi-media module).
    HLDF Main Menu Disabled
    Headphone Socket 1 is Fitted Headphone 1 is fitted.
    Headphone Socket 2 is Fitted Headphone 2 is fitted.
    Headphone Socket 3 is Fitted Headphone 3 is fitted.
    Headphone Socket 4 is Fitted Headphone 4 is fitted.
    Headphone Sockets Fitment Rear headset sockets.
    High Level Display Front (HLDF) Fitment Fitted with high level display front (touchscreen).
    In Band On Channel (IBOC) Receiver Type Not fitted / Disabled
    Integrated Head Unit AM / FM Tuner Fitted
    Integrated Head Unit Error No
    Integrated Head Unit Faceplate Integral faceplate fitted.
    Integrated Head Unit In-Band On Channel Receiver Not fitted / Disabled
    Integrated Head Unit Internal Audio Player Module Type IAM (Internal audio control module) not fitted
    Integrated Head Unit Internal CD Fitted
    Integrated Head Unit Internal DVD Not fitted / Disabled
    Integrated Head Unit Internal Minidisc Not fitted / Disabled
    Integrated Head Unit Low Line Not fitted / Disabled
    Integrated Head Unit Reserved Parameter not used.
    Intercom Fitment Fitted without intercom.
    Internet Parameter not used.
    Media Player 1 Parameter not used.
    Media Player 2 Parameter not used.
    Media Player 3 Parameter not used.
    Media Player 4 Parameter not used.
    Microphone Fitted with a microphone.
    MiniDisc A minidisc is not fitted.
    Mobile Office Not fitted with mobile office.
    Mode for Navigation Interface (Nav on Move) Disabled
    Multi Media Module (HLDF) Country Rest of world
    Multi Media Module (HLDF) DVD Mechanism Horizontal DVD mechanism. (AsBuilt Value)
    Multi Media Module (HLDF) Feature Level (eg 4x4 Info) High multi-media module fitted.
    Multi Media Module (HLDF) Fitment Undefined
    Multi Media Module (HLDF) Japan Spec Multi-media module for non-Japanese market is fitted.
    Multi Media Module (HLDF) Manufacturer Mode DENSO mode
    My Connected World Parameter not used.
    Navigation System Fitment Navigation is fitted
    Navigation System Region Europe
    Parking Camera Fitment No parking camera fitted
    Rear Screens Fitment Yes
    Rear Seat Entertainment Additional Display 3 Not fitted / Disabled
    Rear Seat Entertainment Additional Display 4 Not fitted / Disabled
    Rear Seat Entertainment Additional Display 5 Not fitted / Disabled
    Rear Seat Entertainment DVD Audio Configuration Not DVD audio compatible.
    Rear Seat Entertainment DVD Player Fitment DVD player is not fitted
    Rear Seat Entertainment Error No
    Rear Seat Entertainment Interface Module Fitment Interface module not fitted
    Rear Seat Entertainment Left Hand Display Fitment Not fitted / Disabled
    Rear Seat Entertainment Reserved Not fitted / Disabled
    Rear Seat Entertainment Right Hand Display Fitment Not fitted / Disabled
    Region for Low Line Infotainment Europe
    SDARS Error No
    SDARS Receiver Type Undefined
    Satellite Digital Audio Receiver Fitment Not fitted / Disabled
    Satellite Digital Audio Receiver Non Fitment Not fitted / Disabled
    Short Message Service (SMS Read List) Enabled while driving
    Sirius Telephone Number 8885397474
    Speech Control Language 0
    Steering Wheel Controls 1 Resistive ladder
    Subwoofer Complete with audio integrated subwoofer.
    Television Receiver type Receiver not fitted.
    Television Type Television not fitted
    Text to Speech Language 0
    Traffic Message Channel (TMC) Receiver Fitment With traffic message channel.
    Vehicle information and Communications System (VICS) Vehicle information and communication system not fitted.
    Venture / Companion Cam Disable Speed Undefined
    Venture / Companion Camera 1 Not fitted / Disabled
    Venture / Companion Camera 2 Not fitted / Disabled
    Venture / Companion Camera 3 Not fitted / Disabled
    Venture / Companion Camera 4 Not fitted / Disabled
    Venture / Companion Camera 5 Not fitted / Disabled
    Venture / Companion Camera Docking Station Companion not fitted.
    Venture / Companion Camera Frequency Companion frequency 433.
    Voice Control Fitted with voice control (hosted via the multi-media module).
    3 Flash Turn Signals Disabled
    Adaptive Front Lighting System Fitted
    Auxiliary Driving Lights Not fitted / Disabled
    Canadian Daytime Running Lights Disabled
    Corner Lights Disable Disabled
    Corner On Light Threshold 40
    Cornering Lamps Fitment Fitted
    Daytime Running Lights Not fitted / Disabled
    Exterior Lights Reserved Not fitted / Disabled
    Fog Lights Operate with Side Lights Disabled
    Front Fog Lights Not fitted / Disabled
    Front Fog Lights Go off with High Beam On Disabled
    Headlamp Delay 30s
    High Beam Lights Not fitted / Disabled
    Interior Light Flash Confirm Enabled
    Interior Lights Not Active With Ign in Auxiliary or Off No
    Interior Lights Off Delay 60
    Interior Lights On with Tail Gate Ajar Disabled
    Interior Lights on Approach Not fitted / Disabled
    Lights On when Windshield Wipers On Disabled
    NAS Trailer Lights Disabled
    North American Specification lights Not fitted / Disabled
    Police Lamps Disabled
    Rear Fog Lights off when Trailer Connected Disabled
    Reduced Swivelling Not fitted / Disabled
    Scandinavian Daytime Running Lights Disabled
    Side Markers Not fitted / Disabled
    Static Bending Lights Disabled
    Use Reverse Lights for Follow Me Home Disabled
    Xenon Head Lights Fitted
    Battery Type Undefined
    CCF Last Programmed Day 34
    CCF Last Programmed Month 9
    CCF Last Programmed Year 5
    CCF Part Number for Mcodes NNV501848
    Configuration File Version 25
    Jaguar Cruise Control Undefined
    Jaguar KPH Offset + 0.0kph
    Jaguar Legacy Tyre Size LSB 0
    Jaguar Legacy Tyre Size MSB 0
    Jaguar NAS Safety Belt Sound Disabled
    Jaguar Percentage Scaling Factor 0.00%
    Jaguar Safety Belt Reminder Disabled
    Jaguar Safety Belt Reserved Disabled
    Jaguar Safety Belt Timeout Disabled
    Jaguar Speedometer Calibration Market Market 0 : 3.5% + 2kph
    Mcode Check Sum Byte 1 132
    Mcode Check Sum Byte 2 72
    Mcode End Padding 212
    Park Distance Control Both
    Passenger's Side Airbag Undefined
    Phantom Options Undefined
    Spare Parameter (194) 0
    Spare Parameter (195) 0
    Time Limited Panic Feature Not fitted / Disabled
    Tyre Pressure Monitoring Display Disabled
    Vehicle Build Day 34
    Vehicle Build Month 9
    Vehicle Build Year 5
    Adaptive Speed Control Country UK/rest of world
    Center Differential Lock Fitment Center differential lock-up is fitted.
    Cruise Control Configuration Speed control is fitted
    Engine Aspiration Type Turbocharger
    Engine Code Name / Type Diesel V6.
    Engine Management System Emissions Market Rest of world
    Final Drive Ratio Least Significant Byte 236
    Final Drive Ratio Most Significant Byte 9
    Fuel Type Diesel engine
    Pulse Width Modulated Cooling Fan Not fitted / Disabled
    Rear Axle Differential Lock Not fitted / Disabled
    Transfer Box Controller Range Change Switch Type Double pole switch
    Transmission Type Automatic transmission is fitted.
    Vehicle Speed Limit Configuration Default speed limit (250KPH)
    Vehicle Wheel Drive Type 4 wheel drive vehicle
    Alarm Duration by Market No
    Alarm Fitment Fitted
    BBUS Battery Backed Up Sounder Fitment Fitted
    Battery Delivery Mode Not fitted / Disabled
    CDL Auto Relock Disabled
    CDL First Press Superlock Enabled
    CDL Global Close Disabled
    CDL Global Open Disabled
    CDL Key in Barrel Disarm Disabled
    CDL Steering Column Lock Not fitted / Disabled
    CDL Superlock Chirp Disabled
    Deployable Battery System Undefined
    Door Unlock at Engine Off Disabled
    Driver and Passenger Safety Belt Pretensioners Not fitted / Disabled
    Driver's Front Airbag Not fitted / Disabled
    Driver's Inflatable Tubular Structure Undefined
    Driver's Knee Airbag Undefined
    Driver's Rear Head Airbag Undefined
    Driver's Safety Belt Buckle Switch Undefined
    Driver's Side Airbag Undefined
    Duration of Alarm in Seconds Undefined
    Entry Delay / Audible Confirm Entry delay
    Forward Collision Warning Disabled
    Interior Volumetric Sensor Fitment Fitted
    Key in Boot - Anti Lock-In Protection Undefined
    Locking Delivery mode Not fitted / Disabled
    Locking Flash Feedback Confirms Latch Status No
    Number of Alarms per Activation Undefined
    Number of Alarms per Cycle Undefined
    Number of Alarms per Perimeter Trigger Undefined
    Number of Triggers per Sensor Undefined
    Passenger Airbag Deactivation Lamp Not fitted / Disabled
    Passenger Occupancy Sensor (OCS) Fitment Undefined
    Passenger's Airbag Deactivation Switch Undefined
    Passenger's Front Airbag Undefined
    Passenger's Inflatable Tubular Structure Not fitted / Disabled
    Passenger's Rear Head Airbag Undefined
    Passenger's Safety Belt Buckle Switch Undefined
    Passive Entry Not fitted / Disabled
    RF Global Close Permitted No
    Remote Start Not fitted / Disabled
    Security Error Tone Disabled
    Security Market Undefined
    Side Object Detection System Not fitted / Disabled
    Speed Related Locking Disabled
    Sunroof Lazy Close Not fitted / Disabled
    Superlocking Disabled
    Tail Gate / Boot Lid Power Striker Not fitted / Disabled
    Tilt Sensor Not fitted / Disabled
    Turn Signal Flash on Arm/Disarm Disabled
    Turn Signal Flash on Error Disabled
    Vehicle Horn on Alarm Enable No
    ATR Grass/Gravel/Snow Mode Resets After Time No
    Adjustable Pedal Box Not fitted / Disabled
    Clock Display Format 24 Hour clock
    Column Tilt Inching Not fitted / Disabled
    Driver's Seat Type Undefined
    Easy Entry Memory Not fitted / Disabled
    Heated Steering Wheel Not fitted / Disabled
    Lazy Entry Memory Not fitted / Disabled
    Memory Seats Fitted
    Memory Steering Column Not fitted / Disabled
    Mirror Dips when Reverse Selected Active
    Passenger Seat Type Undefined
    Seat Layout 7-seater style.
    Telescopic Column Inching Not fitted / Disabled
    ACC Indication in Instrument Cluster Disabled
    Automatic Speed Limiter Display Type Automatic speed limit full display
    Automatic Speed Limiting Disabled
    Battery Health Warning Disabled
    Belt Minder Disabled
    Brake Pad Wear Warning in Instrument Pack Disabled
    Dash Board Display Type / Configuration Not fitted with road traffic information/display on the centre console
    Diesel Particulate Filter Service Interval Announcer Disabled
    Distance Units Miles
    Fuel Economy Units Miles/gallon (UK)
    Gallon Type Imperial
    Gauge Sweep Disabled
    Instrument Pack Type Message centre is fiited.
    Key in Audible Warning in Instrument Pack Disabled
    Language Selection UK English
    Lights on Advice in Instrument Pack State 3
    Low Coolant Level Warning in Instrument Pack Disabled
    Oil warning in Instrument Pack Oil pressure switch
    Overspeed Warning in Instrument Pack Disabled
    Park Aid Display None
    Pedestrian Impact System Warning in Instrument Pack Disabled
    Recorded Service Distance Least Significant Byte 192
    Recorded Service Distance Most Significant Byte 93
    Recorded Service Fuel Least Significant Byte 148
    Recorded Service Fuel Most Significant Byte 4
    Reserved for Battery Type / Monitor System Option Not Found
    Reserved for Future Instrument Pack Use 1 Disabled
    Reserved for Future Instrument Pack Use 2 Disabled
    Reserved for Future Instrument Pack Use 3 Disabled
    Reserved for Future Instrument Pack Use 4 Disabled
    Reserved for Future Instrument Pack Use 5 Disabled
    Reverse Warning Display in Instrument Pack Not fitted / Disabled
    Safety Belt Minder in Instrument Pack Configuration Safety belt warning - active (hardwired).
    Smart Key Battery Low Warning Disabled
    Speed / Cruise Control Display Type No speed control display
    Speedometer Offset 127
    Temperature Units °C (Degrees Celcius)
    Trip Computer Metric Fuel Economy Units l/100km
    Variable Damper System Warning in Instrument Pack Not fitted / Disabled
    Daytime Run Lamps Wash Strategy Scandinavian
    Drip Wipe Feature Not fitted / Disabled
    Headlamp Wash Fitted
    Headlamp Wash with Daytime Running Lights Disabled
    Programmed Wipe Fitted
    Rain Sensor Sensitivity Level 1
    Rain Sensors Fitted
    Rear Continuous Wipers No
    Speed Dependent Front Windshield Wipers Yes
    Speed Dependent Intermittent Windshield Wipers Yes
    Windshield Wipers up-stroke Wash Not fitted / Disabled
    ABS fitment ABS is fitted.
    Brake Assist Not fitted / Disabled
    Dynamic Stability Control Dynamic stability control is fitted.
    Electric Park Brake Apply on Stall Not fitted / Disabled
    Electric Park Brake Auto Release Fitted
    Electric Park Brake City Mode Fitted
    Electric Park Brake Dynamic Brake Lights Fitted
    Electric Park Brake Fitment Fitted
    Electric Park Brake Release on Shift from Park Not fitted / Disabled
    Front Brake Type by Min Wheel Size 17 inch
    Key-out = Apply EPB (Manual Gearbox) Not fitted / Disabled
    Rear Brake Type by Min Wheel Size 17 inch
    TPMS Allowable Deviation Front Hard Heavy Load 100
    TPMS Allowable Deviation Front Hard Light Load 100
    TPMS Allowable Deviation Front Over Heavy Load 0
    TPMS Allowable Deviation Front Over Light Load 121
    TPMS Allowable Deviation Front Soft Heavy Load 25
    TPMS Allowable Deviation Front Soft Light Load 25
    TPMS Allowable Deviation Rear Hard Heavy Load 100
    TPMS Allowable Deviation Rear Hard Light Load 100
    TPMS Allowable Deviation Rear Over Heavy Load 0
    TPMS Allowable Deviation Rear Over Light Load 101
    TPMS Allowable Deviation Rear Soft Heavy Load 25
    TPMS Allowable Deviation Rear Soft Light Load 25
    TPMS Allowable Deviation Spare Hard Heavy Load 25
    TPMS Allowable Deviation Spare Over Heavy Load 0
    TPMS Allowable Deviation Spare Soft Heavy Load 0
    TPMS Allowable Deviation Spare Soft Light Load 25
    TPMS Allowable Deviation Spare Soft Light Load 0
    TPMS Spare Wheel No
    TPMS Target Front Heavy Load 23
    TPMS Target Front Light Load 23
    TPMS Target Rear Heavy Load 29
    TPMS Target Rear Light Load 25
    TPMS Target Spare Heavy Load 0
    TPMS Target Spare Light Load 0
    Tyre Aspect Ratio Undefined
    Tyre Dynamic Rolling Radius LSB 114
    Tyre Dynamic Rolling Radius MSB 1
    Tyre Pressure Monitor / Warning System Tire pressure monitor system is not fitted.
    Tyre Pressure Monitor Switchable Pressures Push Button Switchable pressures disabled.
    Tyre Pressure Monitor System Transmitter Frequency 315MHz
    Tyre Width Undefined
    Wheel Rim Diameter Undefined
    Wheel Rim Width Undefined
Exclamation
In terms of understanding them, it's best to go on a basis of what you want to achieve at any given time. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #340055 31st Jul 2015 8:08am
If you have a play and cock it up you can always restore to original settings.... Thumbs Up Pete
Post #340061 31st Jul 2015 8:35am
Lost for Words
Yes, but things could be worse than that. We're talking about the IID here, so I wouldn't be so concerned, but a corrupted CCF casued by my Nanocom was harder to deal with since it was the PCM's copy (D3) that became corrupted. Top marks to GAP for their willingness to help despite it being caused by a different tool... Bow down
Also, SNOTM, for instance, would need the whole process re-doing if the CCF option is disabled.
The IID is very trustworthy (I've vowed not to flash with the Nanocom again Whistle ), but still, the fewer times you flash an ECU, the better. Thumbs Up Visiting from DISCO3.CO.UK
Post #340067 31st Jul 2015 8:57am
6029 king Stephen
United Kingdom 2008 Range Rover Vogue SE TDV8 Rimini Red
Is it possible to use the tool with more than one Land Rover product? For example, I have a 2003 (53) Range Rover but I have friends who have Discovery 3 and 4, could the one tool be used on all models or is it specific to one model or chassis number?
Regards,
Steve
Post #341784 11th Aug 2015 9:04am
http://www.fullfatrr.com/forum/post322818.html#322818 ... - .- -.
Post #341803 11th Aug 2015 10:23am
