Home > Technical (L322) > Air suspension - advice needed please
Brian
Ok , so my car went in for a service last month and the day after it came out the "air suspension inactive" light came on - thought that a bit odd as while sometimes slightly slow to reach full height when asked it has usually worked ok. Got the mechanic to reset the computer and all was well for 2 days and then it came back on again.
So, should I bite the bullet and just swap out the compressor for a new one - or buy the kit for £25 and spend the time putting it in bearing in mind the car is 11 years old and therefore so is the motor and the rest of the compressor - I intend to keep the car so while money is tight at the moment I am leaning towards a new one and then at least I know its good
So finally, as I am in Northern Ireland if I do decide to go down the full replacement road, where would be the best place to buy one at a reasonable rate?
Post #339697 29th Jul 2015 11:10am
try a battery reset first with the obligatory steering parameter setting procedure....not saying this will solve your problem but you never know.. ... - .- -.
Post #339707 29th Jul 2015 12:07pm
The only part that wears is the piston ring, the motor should outlive your FF by years...
Re ringed my 2002 well used example and it is back to factory spec....
Got to be worth the gamble.... Thumbs Up Pete
Post #339721 29th Jul 2015 1:46pm
Get your mechanic to tell you what the fault is! Evil or Very Mad
You can spend money and time chasing a fault.... Thumbs Up .
Post #339779 29th Jul 2015 8:46pm
