Home > General > jacks..
Page 3 of 4 <1234>
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
From bitter experience recently when I lost a wheel from my 90 while off road, on a night navigation run, in very deep mud I don't recommend using a battery powered hammer action drill as a windy hammer - they don't have sufficient torque or even enough battery power to get a wheel nut tight.............. or even 5 of them on one wheel it appears Whistle Whistle next additional weight extra to fit to the 90 - a compressor powerful enough to drive a pneumatic windy hammer...... when will buying all these "bitter experience" extras stop I seem to be caring half a service bay and half a 90 in spare parts these days when i go off into the hills for the weekend?
BTW does anybody know what the wheel nut torque for an L322 should be? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #33900 26th Oct 2010 9:31pm
140nm's tim... ... - .- -.
Post #33909 26th Oct 2010 9:46pm
Fox
I always put my wheel nuts on with a rechargable impact gun, then torque them up with a bar. Thumbs Up
Having something to do with PSV vehicles and they guys from VOSA makes you a bit anal about things like that.
Post #33917 26th Oct 2010 10:25pm
Then re-check then later that day or the next day
Post #33920 26th Oct 2010 10:30pm
Fox
In theory yes. But don't do a daily defect check every day before I use the vehicle. Wink
Post #33922 26th Oct 2010 10:32pm
Tim in Scotland
Thanks for the torque, I thought it was that but haven't seen it anywhere - Defender and RRS are the same. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #33931 26th Oct 2010 11:39pm
SteveMFr
Site Sponsor
Something I learned from the master technician at the shop where I was working at 17. All steel (wheels, lugs) and a powerful impact gun/good compressor - then maybe, just maybe w/o a torque wrench after hitting each lug twice with the impact (and knowing that if the owner has a flat the ugly language will be thick). Otherwise always click each lug.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #33940 27th Oct 2010 7:31am
i used to do nuts up with a windy gun and got them done up with just the right torque, mind you 23 years in the tyre trade helped me judge how long to press the windy gun trigger..... ... - .- -.
Post #33955 27th Oct 2010 10:21am
Discocuzzy
Takla air jack Thumbs Up , high lifts are so dangerous if you have not been shown how to use properly.
Post #34183 28th Oct 2010 11:13pm
M44K TS
Scarey, Mine is an Arcan XL35R 3.5t jack, lift height according to the spec's is around 55cm
http://www.arcanusa.com/lifting.html 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #34185 28th Oct 2010 11:22pm
thanks mark, i thought that i might need something in the region of a 55cm lift .. ... - .- -.
Post #34198 29th Oct 2010 9:06am
Tim in Scotland
It's about time LR designed a compressed air outlet into the boot so you can use compressed air tools and jacks using the car's own compressor off road 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #34217 29th Oct 2010 11:43am
M44K TS
Mind you, that just say lifts the wheels off the ground enough to get them off! 2006 Mercedes CLS
Post #34237 29th Oct 2010 1:49pm
mark, do you lift on the chassis or the jacking points just below the doors... ... - .- -.
Post #34300 29th Oct 2010 4:41pm
M44K TS
To be honest, I've only used it once on the RR and that was when I first got it (when I took the pics) so I can't remember where I jacked it from, I think from the jacking point below the doors. I need to whip the wheels off anyway to clean the dirt off wheel arch liners anyway, I'll try from the chassis and see if it lifts any higher. 2006 Mercedes CLS
Post #34309 29th Oct 2010 5:12pm
Page 3 of 4 <1234>
