Home > General > Touchscreen auto dimming
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
My touchscreen did this from the start, in the evening, at twilight, it just starts to dim for a few seconds and then brightens up and dims again until a certain light threshold is reached and it recovers normal functionality. If I cover its light sensor it brightens accordingly, it’s just a certain exterior light level it doesn’t like. I suppose it’s impossible to fix/adjust but maybe someone has an idea?
Post #33914 26th Oct 2010 8:59pm
What about the light settings in the sub menu's
Post #33915 26th Oct 2010 9:02pm
adara
Yes tried that but it still dims/brightens even at lower or higher settings...
Post #33916 26th Oct 2010 9:06pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
It's like I would like to raise the light level that the auto-on headlights come at, I think they come on too late, it's almost dark by the time they switch on. I tried to get the dealer to adjust it on my RRS but they said it wasn't possible. These days I don't bother with the auto-on setting, I drive around all the time using dipped headlights, roll on proper DRL's as bright as Audi and Mercedes fit to their cars. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #33933 26th Oct 2010 10:51pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
I do not think it's impossible, but I also think that nowone can do it....
Mine suffers from the same, it dims and undims very quickly. It almost reacts to street lamp posts...
But, as far as I remember, when new, it had a very soft dim, something that you couldn't see, except the fact that the screen seemed the same under darkness or under the lights.
Must be something to do with the sensor and it's communication with the ECU.
Told the guy at the service that the car did this, and it came back the same...
Post #33936 26th Oct 2010 11:14pm
adara
I will try to blacken the sensor today and see what happens.
Post #33941 27th Oct 2010 6:49am
adara
Obstructing the sensor only made things worse, the screen was washed out so I’ll live with the dim/undim at twilight for now…
Post #34008 27th Oct 2010 3:35pm
