Home > Technical (L322) > 2007 TDV8 gas pedal response.
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Just a quick question about normal gas pedal response in these. Does you car also seem to be very 0/1 in this matter?
I have a feeling that when I want it to start moving applying up to half the throttle can be barely felt, car seems sluggish, laggy, but when you floor it it goes fine and quite fast for its weight. Feels a bit as if there was not much inbetween, kind of like crawl or run Smile
Is something wrong with my car or do they all do this?
I realise i came into this TDV8 from a 911 Turbo so I do not expect amazing off the line performance as it is one heave boat on wheels but still just the gas pedal response itself seems a bit strange.
Post #339119 26th Jul 2015 7:17am
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
There is a around half a second turbo lag coming from low revs before the first turbo spins up, once it has, seams fine, could that be what you are experiencing?
It's never going to drive like a Porsche unfortunately. __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #339122 26th Jul 2015 7:39am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I get exactly the same feel in my 2006 4.2sc and have been wondering if something is wrong, i will watch this thread with interest.
Post #339136 26th Jul 2015 8:12am
The throttle linkage is electronic. The pedal is basically a big potentiometer which may be faulty. Though as said above coming from a petrol car to a big TD will introduce a bit of throttle lag from standstill. There is nothing that can't be fixed with a hammer😜😜
Post #339137 26th Jul 2015 8:21am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I can relate to this......my 2006 SC throttle is very sensitive. If I need to accelerate from say a slow speed and just want to do so gently there feels like there is literally mm in the throttle required. Any more than that and all hell is let loose, kicks down etc. and you're off. It is a bit tiring and I have wondered whether there is any kid of throttle body that needs cleaning. It sounds like I am not alone! 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #339138 26th Jul 2015 8:35am
