Home > Maintenance & Mods (L322) > 2011 Keyless Vogue Deployable Side Steps Operation |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35381 |
welcome to the forum julian,
23rd Jul 2015 6:46pm |
JulesS Member Since: 23 Jul 2015 Location: Hampshire Posts: 8 |
Hi Stan, thanks for that but i'd seen that thread and it's a no go. It seems the later cars are differing in operation from the earlier ones.
24th Jul 2015 5:10pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Don't the steps come out when you open a door? That being the case just leave a door open when you jack the car up. |
24th Jul 2015 5:14pm |
Hi, yes Zirconblue they do but I know you can lock them out somehow and want to know how to do this - there is always the danger someone might shut a door (garage, tyre dealer etc) and if the car is on the jacking point then knacker the electrics or worse make it unstable.
24th Jul 2015 5:19pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
I usually open the door let the step come out & then simply unplug the step (at the front) leaving NO chance of it moving
24th Jul 2015 5:23pm |
Ah thanks Cam-Tech-Craig, that sounds like a great idea, I didnt know there is a plug accessible at the front, when it stops raining I'll go and have a look underneath the car!
24th Jul 2015 5:27pm |
Pop the suspension up onto off road first, its easier to see it |
24th Jul 2015 5:30pm |
You're a very useful chap Craig - thanks, will do (I normally only get to use this mode when jetwashing the wheel arches as off roading on 22" wheels is a no-no ) |
24th Jul 2015 5:33pm |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
I have those deployable steps on a 2011.5 and even with the handbook it can be a bit challenging but here goes.....
25th Jul 2015 3:24pm |
Hi David, thanks, I tried that and didn't want to work but will try again, cheers |
28th Jul 2015 10:13am |
My car is in France and I am in the UK or else I would quote from the manual!
28th Jul 2015 10:37am |
