![]() | Home > Maintenance & Mods (L322) > 2007 TDv8 |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Welcome |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Are you talkling about the the corrosion at the front of the arch, where the door closes over ?? If it is then I would say it cos of crud getting caught between the arch and the wheel liner and just sitting there as a moisture trap. Also with the door rubber closing over that area on the outside, it will scratch the surface of the paint, due to the crud that gets thrown up from the road, when the doors are opened/closed. Again sealing moisture in. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Have a search on here, there are loads of bits and bobs to do in terms of preventative maintenance.
MAZI Member Since: 14 Dec 2013 Location: EDINBURGH Posts: 15 ![]() ![]() |
Best seller of replica supercharged grills?
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Significant issues on mine with same age:
