![]() | Home > Maintenance & Mods (L322) > L322 air suspension pipe worn through |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
something like this :
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
Yes, exactly. Just wondering about sizing? I guess you can measure the internal and external diameters. I don't have the car here at the moment so I can't do this right away. Also, access is a bit of an issue. |
Also, anyone know what the maximum air pressure is in the system when fully working? |
found this :
Ah. Looks like the plastic ones are not up to spec.
I think they will do it on the pressure front, just need to get the right size for the piping |
This seems more informative:-
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Might help
Is similar. Thanks. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Ha, I remember my old post well... and the cold...
I have ordered the kit with a section of pipe and 2 connectors. Hopefully, that will cover any eventuality.
The parts came today and I was able to cut out about 10mm of worn pipe and then insert one of the straight connectors.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8530 ![]() ![]() ![]() |
That was a lovely cheap fix... top job...
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
