Home > In Car Electronics (L322) > Sat Nav States 'Navigation Not Fitted'
jeep948
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Mariana Black
As in the title; Sat Nav States 'Navigation Not Fitted', I have disconnected the unit YIB500070 and checked for a feed to make sure it is getting power, of the 3 plugs that go into the rear the multiplug gives on positive feed to the unit (which i can only assume is correct), at this stage I am unsure if the unit is faulty or if the issue lies elsewhere i.e
Is there meant to be another live feed into the unit other than the one mentioned above?
Is there an issue with the unit not being properly connected to the bak of the screen, if so how and what do i strip to gain access?
Or is it just a case of the unit being faulty and needs repaired/replaced? If so where is best to go for either of these options?
Thanks in advance
Post #337819 18th Jul 2015 2:42pm
Welcome to the forum, I take it from your name you own an American vehicle...!!!
If you do own a Range Rover then it would be handy to know which model you have...??? Pete
Post #337821 18th Jul 2015 3:06pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Aren't the sat nav modules & bits in the left rear quarter?
May be worth checking plugs etc are all ok back there. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #337827 18th Jul 2015 3:43pm
RJH
P.S. Welcome to the forum Thumbs Up 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #337828 18th Jul 2015 3:45pm
jeep948
Hi Pete,
Thanks For the Welcome, I actually joined a couple of years ago but have never posted until now.
I used to own a Jeep Cherokee some 20 years ago now and the handle has kind of stuck as i have used it on various other sites.
I have update my avatar with a picture of my current RR's, but the vehicle I am referring to in the post is my RRS Supercharged.
Thanks David Range Rover P38 4.0 HSE
Range Rover Sport 4.2 Supercharged
Post #337841 18th Jul 2015 5:52pm
jeep948
Thanks for the welcome.
The nav unit is under the passenger seat, I have removed it and that is as far as I have got.
Are you saying that there should be more in the left rear quarter behind the panelling?
Thanks Range Rover P38 4.0 HSE
Post #337843 18th Jul 2015 5:55pm
mjdronfield
Hi David
Welcome.
Have you looked on the Range Rover Sport forum ?
http://www.rrsport.co.uk/forum/
You might get a more accurate answer over there.
The reference to the electronics in the left hand boot compartment is for the full fat Range Rover.
Not sure if the parts are shared with the L322 / L405 ?
Does the Discovery have the same nav unit fitted ?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #337848 18th Jul 2015 6:44pm
Zirconblue
Which car are we talking about? The Sport or the P38?
Post #337850 18th Jul 2015 6:55pm
mjdronfield
His rrs according to the 5th post.... Unless I am mistaken.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #337851 18th Jul 2015 6:58pm
the RRS has the nav unit under the passenger seat, the FF nav unit is in the near side rear cubby hole. ... - .- -.
Post #337854 18th Jul 2015 7:19pm
jeep948
mjdronfield wrote:
Hi David
Welcome.
Hi and thanks for the welcome,
The Discovery shares the same unit as the RRS.
TBH I have posted some questions on the RRSport forum already and have no response so far, hence I thought i would try on here to see if I fared any better.
Post #337954 19th Jul 2015 1:16pm
