Home > General > jacks..
Page 1 of 4 1234>
jacks..
just done my front discs and pads and i had loads of effort in jacking the FFRR up using a bog standard 2ton argos type jack...does anyone use the 'farm/4x4' type that works on a ratchet system, if so are they nay good for the RR.... ... - .- -.
Post #33757 26th Oct 2010 2:01pm
I have a very old 3 ton EPCO trolley jack that belonged to my father, it lifts the FFRR easily.
Do the ratchet jacks have enough reach to lift a FFRR?
Another alternative would be a truck bottle jack, they have a lifting capacity of around 20 tons and are not expensive
Post #33760 26th Oct 2010 2:24pm
iT LAD
Would love to be able to change my pads and stuff myself... dumb arse in that department...
Post #33761 26th Oct 2010 2:35pm
@47p2..they have a 'safe' reach/lift of 50cm with 2 1/2 tons which is probably high enough to lift one corner of a FFRR....
@rob...you've got talents in other depts and when you get your fairly new FFRR, the dealer will take care of these things... ... - .- -.
Post #33763 26th Oct 2010 2:42pm
Fox
Re: jacks..
The farm 4x4 type is IMHO for recovery offroad only.
I would never work on a vehicle held by one as they are not very stable.
They will also have nothing on a FFRR to attach to, as you need a strong mounting point on the outside of the vehicle.
Post #33764 26th Oct 2010 2:44pm
there are four jacking points on the FFRR and to only fit a spare on the roadside for instance , surely these jacks would be ok....
i might have given the impression that i wanted one of these for maintenance work ,sorry..
edit........useful link
http://www.fjcruiserforums.com/forums/4x4-...-jack.html ... - .- -.
Post #33768 26th Oct 2010 2:48pm
M44K TS
I use a 3 ton low profile high lift jack from Costco, was about �90. Here it is almost at full lift..
Perfect for my work van too, (LWB Vivaro) but a little ott when I use it on the Mini Laughing 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #33783 26th Oct 2010 4:18pm
crikey thats a bit close to the van !!!
looks like that jack does the job... Thumbs Up
btw, whats the reach on your jack? ... - .- -.
Post #33788 26th Oct 2010 5:09pm
My preferred method Thumbs Up
Post #33795 26th Oct 2010 5:24pm
Fox
Yes, that's the farm 4x4 jack I thought you mean SCarey. Often called a Hi-Lift as they sell a lot of them.
The jacking point on the FFRR is not suitable. You need an all enclosed tube right upto the jack. See a defender bumper or rock slider for an example.
With the curved side of the FFRR you can't get close enough even if it did fit, which I don't think it does.
They are also far more unstable than nearly every other jack out there. A bit of side pressure and they go over very easy. Shocked
Post #33799 26th Oct 2010 5:31pm
madkoka
Now thats just showing off Laughing Thumbs Up
Post #33800 26th Oct 2010 5:34pm
never thought about the RR side profile ..makes a lot of sense now you've pointed it out...i'll have to look for a reasonably priced [3ton?] trolley jack with a high reach ... ... - .- -.
Post #33801 26th Oct 2010 5:34pm
Fox
The one Maak uses is perfect. I have the same. Thumbs Up
Post #33802 26th Oct 2010 5:37pm
have you the jack's spec FOX? ... - .- -.
Post #33803 26th Oct 2010 5:38pm
The jacking beam is air operated and has a 1.5 ton weight limit, more than enough for the front or back of my vehicles.
These were taken before the roof trusses were removed
Post #33806 26th Oct 2010 5:41pm
Page 1 of 4 1234>
