Home > In Car Electronics (L322) > 753 hidden menu - 2010->
Just managed the make the 05-09 touchscreen hidden menu idea work on my 2012 👍
Go back to the home menu, with the options down the left side.
Press and hold the top centre of the screen for a few seconds
Press and hold the navigation hard button on the left side until the keypad appears
Enter 753 then ok.
👍👍👍👍 There is nothing that can't be fixed with a hammer😜😜
Post #337074 12th Jul 2015 5:10pm
pld118
What does that give you then?
Post #337083 12th Jul 2015 5:27pm
Same as on the old ones. Can play with the vid inputs and see the voltage. That sort of thing. There is nothing that can't be fixed with a hammer😜😜
Post #337085 12th Jul 2015 5:37pm
pld118
Never knew any of that Thumbs Up
Post #337087 12th Jul 2015 5:40pm
DrRob
Going to try this later. Can you also view rear camera when in D via this menu?
What else can you do or change?
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517782 8th Jun 2019 12:22pm
rjff
Mine shows the rear view camera when moving.
As NMJ says, the voltage display shows and could be useful if you suspect an alternator failing and don't have a meter to hand. All sorts of codes and info also visible, but haven't tried them all. Cheers
Richard
Gap IIDBT
Post #517790 8th Jun 2019 1:21pm
DrRob
Cool. Can it be accessed with engine running? I prefer not to flatten batteries Shocked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517791 8th Jun 2019 1:23pm
rjff
I think it has to have the "ignition" on. With the engine runnning the camera still shows, so would assume that the rest comes up. Cheers
Richard
Gap IIDBT
Post #517792 8th Jun 2019 1:25pm
rjff
Update
Forgot to say the reverse camera doesn't come on as usual when selecting reverse gear with a diagnostic/info screen on. Cheers
Richard
Gap IIDBT
Post #517793 8th Jun 2019 1:32pm
