Home > Maintenance & Mods (L322) > Dog guard
wealy
Dog guard
I am about to get a new dog!
I guess I will need to get a dog guard and there is quite a variety on ebay. DO I need to get a genuine Land Rover one or do the cheap copies work OK?
Any advice appreciated?
Post #335840 4th Jul 2015 4:23pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi
I picked up a genuine full size fo £60, I would go for one of these from the flee bay, as they seem to go reguly for less than £100 SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Triumph Bonneville 1970
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
4.2 E type Jag replica (challenger)
Escort RS2000 (many)
Escort RS 1600 Turbo
Post #335841 4th Jul 2015 4:32pm
Zirconblue
If it's tailor made for the Range Rover it should be fine (they're hardly complex engineering), but the generic fit any car ones aren't normally all that great
Post #335844 4th Jul 2015 4:44pm
wealy
How do they fit? are there any holes to drill or permanent fitting?
Post #335845 4th Jul 2015 4:46pm
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
We've got a RR retractable net guard
Pick up for a reasonable price from a member here Very Happy
But the fixing kit is the killer money, but the whole thing is intergrated, does the job and is realatively discrete when retracted
Ian
Post #335851 4th Jul 2015 5:07pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I got the top half type from a member on here. Easy to fit, they just hook into the brackets in the riff then strap down at the bottom.
It should be easy to pick up a decent second hand one for £50ish
Post #335852 4th Jul 2015 5:41pm
Zirconblue
The full height ones attach to the lashing points at the bottom and you'll see some plastic covers in the headlining for top mounts.
Post #335903 5th Jul 2015 3:58am
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I ended up with a dog cage rather than a dog guard after the dog scratched at the rear window and ruined the radio reception. Luckily my insurance company accepted my claim for damaged glass but if you have a large dog it is worth thinking about a cage.
Post #335909 5th Jul 2015 7:07am
Zirconblue
good point, also means you can open the back up at motor way services to air the car out.
Post #335979 5th Jul 2015 4:41pm
