Home > Maintenance & Mods (L322) > How to.... Refurb your door handles...
Page 2 of 4 <1234>
I did post it on my project thread...
I have painted the complete wiper arm on this picture but not the piece of trim under the headlight.... it's as close as you can get, even the metallic sheen is similar...
My before and after bonnet vent
David, mirror caps are easy, they just pull off, if you want to do your handles in body colour you will need to prime them and wet flat them, after the adhesion promoter, the top colour coat is just that, you will see ANY small imperfection when you put the lacquer on.... several coats of primer and then wet flat with 1000grit paper until you have a totally even and flat surface without any breakthrough to the plastic.... It's a fare bit more work than doing them matt...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #278614 2nd Sep 2014 10:46am
utvols2007
United States 2005 Range Rover HSE 4.4 V8 Adriatic Blue
I live in the U.S. and was wondering where I can get that paint color. I have only seen it in the U.K. Where did you get yours?
Post #335046 29th Jun 2015 1:42pm
It's a standard colour, any paint shop will be able to mix it... Pete
Post #335048 29th Jun 2015 2:02pm
utvols2007
Ok. Thanks man!
Post #335052 29th Jun 2015 2:17pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Thanks for bumping the topic, I need to get mine repainted and this is an awesome writeup. Thanks! Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #335138 29th Jun 2015 6:08pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
As pete says watch the plastic primer, its very runny.
ask me how I know Embarassed
Laughing Thumbs Up
Post #335185 29th Jun 2015 7:57pm
Pete, David drives an 06>MY car so has entirely different mirrors to yours sir... The covers DONT pull off on the later ones! Neutral Neutral Neutral
Post #335224 29th Jun 2015 11:31pm
ooooops.... Bow down Dave, don't pull them off..... mind you that was last September Craig so I guess he hasn't done it yet... Thumbs Up Pete
Post #335226 29th Jun 2015 11:59pm
p38arover
Australia
Pete, how have they held up?
Mine need doing as do the interior plastic trims around the door handles. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #394242 3rd Jul 2016 10:22am
They would be superb if it wasn't for the fact they get worn with bush rash every time I do some laning.... The bonnet trim and lights are spot on still....
I did my mates handles on his shiney just after I did mine and they still look as new.... Thumbs Up Thumbs Up Pete
Post #394709 5th Jul 2016 10:30pm
p38arover
Australia
Thanks Pete. I should pull my finger out and do them. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #394863 7th Jul 2016 7:25am
Sharky1168
Found this on fleabay
http://www.ebay.co.uk/itm/MERCEDES-HQ-SPRA...D100102%26
Will be giving it a try next weekend Current RR L322 TDV8 VOGUE
Past: RR L322 TD6 HSE, Discovery 2. Land Cruiser V8, Saab 9-7x, Nissan Maxima, Ford Granada I, II, III
Post #408304 8th Oct 2016 2:30pm
Blimey that's a lot of money, get it much cheaper from a paintshop supply stores, you will have a local one...
Also the lacquer will be shiny, you need matt lacquer for it to look right... Thumbs Up Thumbs Up Pete
Post #408382 8th Oct 2016 11:29pm
Roverlord
England 2003 Range Rover HSE Td6 Zambezi Silver
I just went to the local automotive paint supplies and got them to mix me up Land Rover colour Brunel in 2 pac. I bought 250ml of it and it wasn't very expensive
Post #408393 9th Oct 2016 1:04am
Sharky1168
Aye it's not cheap, but the kit comes with a primer for plastic (which isn't cheap on its own) and the lacquer says matt finish. Will have a go at it and see what it looks like on a test bit of placcy before attacking the handles & bonnet intake. Current RR L322 TDV8 VOGUE
Post #408521 9th Oct 2016 7:13pm
Page 2 of 4 <1234>
