Home > Technical (L322) > 5.0 SC restricted?
g1968g
5.0 SC restricted?
Hi,
Is the 5.0 SC restricted.
If so, what would the top speed be if it was de-restricted.
cheers
Geoff Looking for FFRR
Post #335085 29th Jun 2015 4:19pm
dont think it is...top end is about 140... ... - .- -.
Post #335154 29th Jun 2015 6:32pm
Zirconblue
How long does it take to drain the fuel tank at 140mph? Laughing
XJ with the same engine does 155mph, which is presumably the limiter. So i would think the Range Rover is only limited by it's size, weight and gearing.
Post #335168 29th Jun 2015 7:11pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Absolutely is restricted, it's obvious there's more to come when you get to the limiter, same as the TDV8. Supercharged L405 is limited to 155 on 22" wheels - supposedly they did 180+ at Nardo in testing. Remember weight has no effect on top speed.
Post #335182 29th Jun 2015 7:33pm
