Home > Maintenance & Mods (L322) > Creaky Arse!
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Creaky Arse!
Hey all
Over the last week I've started to get a more and more louder creaking from the back end of the FF.
At first I thought it was a tight dry rubber, so gave everything a good soak with silicone. But have now come to the conclusion that it's coming from the N/S shock absorber. I've obviously got to Jack it up and have a proper look, but the creaking is beginning to sound more "mechanic" than rubber now.
Shocks arnt leaking but hey. Anyone else had this?
Are they the end of the world to change? I'd obviously change as a pair.
Cheers guys
Tel Accept, some days your the pigeon, some days your the statue!
Post #335124 29th Jun 2015 5:40pm
Usual creak from the rear is an upper or lower hub bush, they creak like mad when worn.... could be the shocker but my money is on a hub bush..... Pete
Post #335134 29th Jun 2015 5:55pm
Boydonegood
Oh really? I've gotta have a proper look but is great to have a starting point!
Real stupid question, but is soaking them in wd40 or soapy water gonna shut them up enough to prove it's them? Or are they not just a rubber bush?
Cheers buddy Accept, some days your the pigeon, some days your the statue!
Post #335136 29th Jun 2015 6:00pm
mjdronfield
Mine does that a bit when it's been really dry for ages. Sounds like an old spring pram.
I cure it by driving up a grass verge from flat at an angle. The axle articulation seems to move the rubbers or whatever and it's silent again for 6 months or so.....
Just a thought....
Not sure wd would do much unless you can get the bushes in a different position, spray them, and the move back, if you see what I mean. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #335149 29th Jun 2015 6:26pm
The hub bushes are a rose joint (hiem joint) within a rubber gaiter... if they end up like mine then yes WD40 will stop them for a bit as the rubber was just about gone, but they could be worn and still have the gaiter in tact... Pete
Post #335158 29th Jun 2015 6:38pm
Madyaker
United Kingdom 2002 Range Rover Vogue 4.4 V8 Barolo Black
Mine has also developed a squeaky rear but when I got SWMBO to bounce on the back bumper while I was underneath it was silent ! Confused All bushes seem solid with no play. Would a dollop of grease around them be beneficial ?
Post #335323 30th Jun 2015 6:48pm
Boydonegood
Made a cut in top and bottom bush gator and squirted a dose of white spray freeze in each. You should see the sh*t that came pouring out!
Gonna bite the bullet and change mine myself. Will cobble a bush puller together outa some threaded bar, large socket and some washers.... Oh and one hell all mighty air nut runner impact gun Wink
Cheers for all the posts guys
Post #335333 30th Jun 2015 7:32pm
No, you can't grease anything, as I said, if the joints have got very bad and the protective rubber covering has gone, then a squirt of WD40 will shut them up for a bit, just to prove it's them..
There are no grease nipples so if anything is worn it needs replacing... Pete
Post #335334 30th Jun 2015 7:34pm
Tel
To be fair there not usually too tight... the bolts on the other hand will be very tight, I snapped one... I'd get new bushes, bolts, washers and nuts.
Got mine from Dan at Duckworths and there not too bad price wise... Thumbs Up Pete
Post #335337 30th Jun 2015 7:37pm
Boydonegood
Oh cheers Pete!
Will order the complete lot as you say. Am going to do it at my works as have the garage there, but Sod's law I'll snap a bolt and be in the sh*t
Thanks for the heads up!
Post #335574 2nd Jul 2015 3:53pm
