Home > Maintenance & Mods (L405) > Changing wiper blades
Page 2 of 5 <12345>
Hobo729
Cyprus 2019 Range Rover Autobiography SDV8 Baltic Blue
Very Strange
Hi Steve, you have me wondering - I had never taken much notice before because as fitted (done by LandRover Solihull) the wipers work perfectly. They do almost touch when parked and the tip of the blade almost touches the A column but as already said - they work perfectly in all respects - smooth and silent. My car is Jan 2013 and was a LandRover Director's car (very short woman driver I think) and is immaculate but the sun has now hardened the wiper rubber so they smear - hence the wish to change them. I will certainly fit both sides with 24" because the screen cleans so well with them. Thanks for making me aware. I will try the Bosch blades Alastair discovered and hope they fit OK as I don't fancy LR prices. Thumbs Up
James
Post #334861 28th Jun 2015 11:23am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi James, you've actually got me thinking along switching to 2 x 24s when the time comes as I always prefer as much screen to be cleaned as possible and you have confirmed my thoughts about where the wipers would sit so I know it should be ok (worst case scenario is that I would have a spare 24" which wouldn't really be a problem anyway). Cheers Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #334952 28th Jun 2015 11:34pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
So do the Bosch ones fit perfectly and as per original design?
Post #335887 4th Jul 2015 9:35pm
Yes - straight swap - they don't look absolutely identical, they are a slightly different style, but are a straight swap & fit perfectly Thumbs Up
Post #335910 5th Jul 2015 8:07am
Hobo729
Perfect
Thanks Alastair - I have fitted the Bosch Blades - both 24" - and they work perfectly. I do notice that the nearside wiper clears a much bigger area than the offside - the 4" extra makes a big difference (as the actress said to the Bishop)
I hope this helps those thinking of going for the extra inches Whistle
Post #337110 12th Jul 2015 8:20pm
JasM
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Does anyone have any idea on how to change the rear wiper blade?
Changing the fronts was simple enough, however the manual makes no mention on how to lower the rear wiper arm. 2014 SDV8 Autobiography Cool
Gone: 2012 RRS SDV6 HSE, 2007 RRS TDV6 HSE
Post #372373 14th Feb 2016 6:38pm
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
Just done mine, bit of a faff - the way l did it was to have the engine running, rear wiper on and open the boot when the wiper was pointing downwards. It is a 17 inch blade with a rather strange fitting which l could only find at a LR dealer and blooming expensive. Unless anyone else has any further ideas.
Keith Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #372408 14th Feb 2016 9:34pm
Jon S
I've bought a new blade from wiperblades.com for the rear but I can't seem to get the old one off!. It's difficult enough getting it in the right position (opening boot as it's sweeping) but it seems well fastened on there- is there some kind of tab I need to press to release it or does it just pull off?
Post #412542 7th Nov 2016 2:46pm
WOW Shocked one need a university degree to change the wiper blades Big Cry Big Cry All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #412630 8th Nov 2016 9:20am
Mine was a standard fitting - I just got a regular 17" blade like this one Thumbs Up
To remove the old one, I just had to push it IIRC
I'm sure Frank has someone who changes his for him Whistle
Post #412677 8th Nov 2016 5:53pm
Honestly ? I would go to my local LR dealer Razz All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #412685 8th Nov 2016 6:54pm
Jon S
I've done it! there is a plastic tab (that looks like a spring to keep the wiper on the screen) - I had to push this down and push the blade up out of the hook.
Phew!
Post #412747 9th Nov 2016 10:04am
DavidRR
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Have used this forum a few times now so thought it was about time I said hello and thank you. Just changed my rear wiper having opened the boot when the arm was at the 6 o'clock position. Amazing that it's such a faff but loving the results of my new Bosch blades (did fronts too).
Thanks for the tip.
David
Post #462795 31st Dec 2017 1:31pm
Post #462814 31st Dec 2017 5:45pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Choice of wiper blade?
Shortly after buying the L405 I changed the OEM blades over to Bosch Aero. I found the LR ones noisy and the Bosch were OK at first but have since become noisy. I don’t think they are yet old enough (few months) to have worn.
As a D3 owner some years ago I followed some online advice to try Valeo Silencio for the Discovery and they were fantastic. I bought replacements for them many times and was very happy with them.
Has anyone found a brand for the 405 (that’s available in the UK/Europe) that they would strongly recommend?
Has anyone tried fitting the Silencios?
Cheers 2016 SDV8 AB
Post #466921 2nd Feb 2018 8:21am
Page 2 of 5 <12345>
