Home > Maintenance & Mods (L322) > Diagnostic Tool
Page 2 of 3 <123>
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Well decision time,
I think I'll invest in the IID unit sold by Gap Diagnostics.
One final question :- If you run autoscan (if its possible), can you upload the file to your pc and print it out?.
Haylands I see you have fitted electric fans, I did the same to my classic Kenlow twin 12inch electric ones, hard wired to the battery It originally had a multi blade viscous fan that always kept running.
When the electric fans kicked in on a hot day it sounded like a jumbo jet throttling up to take off.
Thanks everyone for your comments.
Post #334934 28th Jun 2015 8:55pm
Mikey
You can email, or print out (with a Bluetooth printer) the codes and analyse that way
Same with the live data/logs Thumbs Up
Post #334939 28th Jun 2015 9:43pm
Strider
Thanks Mikey Thumbs Up
Post #334940 28th Jun 2015 10:32pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
So the IID tool can do everything that the dealer software can do or is it lacking something I will never conceive of needing?
Post #334971 29th Jun 2015 2:38am
Mikey
The IID is still being developed, but already, it can do things that even the dealer tools can't do Thumbs Up
Post #334972 29th Jun 2015 6:06am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Guys
Just a few precisions:
Quote:
I prefer hard wired diagnostics, wi-fi etc is fine but if there is a comms drop out ??.
The mobile App basically acts like a remote controls for the IIDTool BT. Communication with the vehicle and functions are all handled by the tool itself. For example, the following is from the user manual:
Notes on mobile App usage: Once started, the re-flashing process is independent from the App and is only handled by the IIDTool. The App is only used to display the current status and can be left in the background, foreground or closed. If the mobile device is disconnected from the IIDTool, the App will recover automatically once re-connected to the IIDTool.
In other words, a disconnection will not create any issues. Also, Bluetooth Smart connectivity is very stable and disconnections are a rare occurrence.
Quote:
And, all those ccf items can be done without the tool anyway, through the dash menu.
True for basic user personalization while more in dept settings can only be changed with a diagnostic tool (tow bar etc…).
Here's our license policy from firmware V3.0:
Standard diagnostic functions (free of charge, all supported vehicles for the IIDTool BT, one single vehicle platform for non BT units)
• Faults read / clear (All ECU’s)
• Live values
• Control outputs
• Service / test functions (service interval reset (oil service), electronic parking brake functions etc)
Enhanced diagnostic functions (VIN locked, tool comes with one license, additional license at around 60 GBP, DA6407. All supported vehicles for the IIDTool BT, one single vehicle platform for non BT units):
• ECU Flash
• Component and system calibration (including suspension height adjustments, when air suspension is fitted to the vehicle)
• Car Configuration File editing capability (for example, activate the reverse screen after retrofitting the rear camera)
• Advanced functions including backup / restore, save profiles – vehicle system settings and
configurations are read and stored as a backup file for a restore function, various changes
to systems (e.g. suspension height) can be stored and changed quickly
Unit transferring:
-Transfer of ownership (unit is sold) costs 25 GBP paid by the new owner. This includes an unlock code for his vehicle*. The enhanced functions will no longer work on the previous owner vehicle(s) once transferred.
-Transferring the unit from one vehicle to another is free of charge for the owner of the tool*. Enhanced functions will no longer work on the previous vehicle once transferred.
*Keep in mind that a non BT unit can only work on one vehicle type (L322 2006-2009 for example) while an IIDTool BT will work on any supported vehicles (L322, L405 etc...). Please consult our website for more details.
Hope this helps.
Cheers http://www.gap-diagnostic.com/
Post #335572 2nd Jul 2015 4:39pm
Strider
Thanks "PatGAPinnov" for the info, its very useful and re-assuring Thumbs Up .
UPDATE: I ordered the IID Diagnostic Tool DA6401 a couple of days ago, looking forwards to having a plug and play Smile .
Is there a site that explains the error code meaning and suggests a solution/s ?.
For example : Vag-com diagnostics + Ross tech Wiki website for code description and possible solutions
Thanks
Post #335601 2nd Jul 2015 8:01pm
theres a fault code link in the wiki.. ... - .- -.
Post #335603 2nd Jul 2015 8:06pm
Lost for Words
As an IID BT user, I just thought I'd add another vote of confidence here. Thumbs Up
It's a great tool and support from Pat and co. is excellent. Bow down Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #335685 3rd Jul 2015 10:15am
SCPB
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Me to. The dealer said it wasn't possible to turn my auto folding mirrors off.......two minutes with the IID BT tool and sorted. I just used my phone as the bluetooth display, works a treat. 2010 5.0 SC Autobiography
Post #337410 14th Jul 2015 10:53pm
I just got my BT version. So much easier to use than the non-BT version.
Managed to get my voice activation back to life after about 2 years of it not working.
I can also view my turbo actuator issue in real time, which will hopefully help with the diagnosis.
Patrick is such a helpful guy to deal with and always takes time to respond to queries. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #337414 14th Jul 2015 11:28pm
tafftoo
2006 Range Rover Supercharged 4.2 SC V8 Java Black
I've got the BT IID and can verify that the support from Pat and Gap is first rate. I've already used it to change a number of settings in my Car Configuration, reset faults, updated the bluetooth ECU and the Body ECU, and updated my Suspension ECU when I went from a failed Hitachi Compressor to an AMK one.
I've used it with my Android Phone and my iPad and it's worked faultlessly.
Post #337573 16th Jul 2015 11:59am
J90
France 2006 Range Rover Vogue Td6 Java Black
I've seen the IID tool inc VAT for £258. The non BT one.
i'll be buying one tomorrow time permitting. (LR parts Liverpool)
What does CCF stand for please.
Post #337593 16th Jul 2015 7:35pm
ccf stands for car configuration file.. ... - .- -.
Post #337594 16th Jul 2015 7:35pm
J90
Thanks Stan.
Post #337595 16th Jul 2015 7:36pm
Page 2 of 3 <123>
